[GRASSweb-list]markus: web/grass51 index.html,1.61,1.62
grass at intevation.de grass at intevation.de
Thu Sep 11 12:51:30 EDT 2003
Author: markus
Update of /grassrepository/web/grass51
In directory doto:/tmp/cvs-serv17277/grass51
Modified Files:
Log Message:
 5.1.0 -> 5.7.0
Index: index.html
RCS file: /grassrepository/web/grass51/index.html,v
retrieving revision 1.61
retrieving revision 1.62
diff -u -d -r1.61 -r1.62
--- index.html	13 Aug 2003 14:32:44 -0000	1.61
+++ index.html	11 Sep 2003 16:51:28 -0000	1.62
@@ -4,19 +4,19 @@
    <DEFANGED_meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
    <DEFANGED_meta name="Author" content="GRASS Development Team">
    <DEFANGED_link rel="stylesheet" type="text/css" href="../sitestyle.css">
-   <title>GRASS 5.1 Development</title>
+   <title>GRASS 5.7 Development</title>
 </head>
 <body>
 <h1>
 <a href="../index.html"><DEFANGED_IMG SRC="../images/grass.smlogo.gif" alt="HOME" ALT="grasslogo" NOSAVE BORDER=0 height=91 width=76 align=CENTER></a>&nbsp;
-GRASS 5.1 Development</h1>
-<a href="../images/grass51_watertower.jpg"><DEFANGED_IMG SRC="../images/grass51_watertower_small.jpg" ALT="3D vectors in GRASS 5.1/NVIZ" NOSAVE align=CENTER></a>&nbsp;&nbsp;&nbsp;&nbsp;
-<a href="../images/grass51trees.jpg"><DEFANGED_IMG SRC="../images/grass51trees_small.jpg" ALT="3D vectors and TIN in GRASS 5.1/NVIZ" NOSAVE height=165 width=234 align=CENTER></a>
+GRASS 5.7 Development</h1>
+<a href="../images/grass51_watertower.jpg"><DEFANGED_IMG SRC="../images/grass51_watertower_small.jpg" ALT="3D vectors in GRASS 5.7/NVIZ" NOSAVE align=CENTER></a>&nbsp;&nbsp;&nbsp;&nbsp;
+<a href="../images/grass51trees.jpg"><DEFANGED_IMG SRC="../images/grass51trees_small.jpg" ALT="3D vectors and TIN in GRASS 5.7/NVIZ" NOSAVE height=165 width=234 align=CENTER></a>
 <a href="../images/grass51_nviz.jpg"><DEFANGED_IMG SRC="../images/grass51_nviz_small.jpg" ALT="Provided by Radim Blazek" NOSAVE height=166 width=267 align=CENTER></a>
 <p>
-GRASS 5.1: [ <a href="#status">Status</a> |
+GRASS 5.7: [ <a href="#status">Status</a> |
 <a href="#features">Features</a> |
 <a href="http://mpa.itc.it/radim/g51/">Screenshots</a> |
 <a href="#development">Development</a> |
@@ -26,17 +26,19 @@
 <P>
 <a name="status"></a>
-<h2>GRASS 5.1 status</h2>
+<h2>GRASS 5.7 status</h2>
-GRASS 5.1 is currently under development. It is neither complete (it still
+[GRASS 5.1 renamed to GRASS 5.7, Sep 11 2003, see <a href="../roadmap.html">roadmap</a>] <P>
+GRASS 5.7 is currently under development. It is neither complete (it still
 contains only a few modules) nor it is intended to productional usage.
 Development releases are provided for people who want to help test, debug,
-and improve GRASS 5.1. Knowing this, please read on. The modules already
+and improve GRASS 5.7. Knowing this, please read on. The modules already
 present in this version can be seen <a href="manuals/html51_user/index.html">here</a>
 (this list is updated weekly).
 <a name="features"></a>
-<h2>GRASS 5.1 features</h2>
+<h2>GRASS 5.7 features</h2>
 The improvements of the vector architecture
 cover the new 3D multiattribute, multilayer vector library,
 a modified NVIZ and a few database management tools.
@@ -108,40 +110,40 @@
 </ul>
 </ul>
-The 5.1 code (still) requires the experimental tree of GRASS 5.0 code to
+The 5.7 code (still) requires the experimental tree of GRASS 5.0 code to
 compile (note: the preX release won't work!) as it will be partly merged
-into the 5.1 directory structure during compilation. From time to time more
-code will be migrated into 5.1.
+into the 5.7 directory structure during compilation. From time to time more
+code will be migrated into 5.7.
 <a name="development"></a>
-<h2>GRASS 5.1.0 development</h2>
+<h2>GRASS 5.7.0 development</h2>
 <ul>
 <li>New vector engine:
 <ul>
-  <li>GRASS 5.1 Vector architecture description: <a
+  <li>GRASS 5.7 Vector architecture description: <a
    href=http://www.ing.unitn.it/~grass/conferences/GRASS2002/proceedings/proceedings/pdfs/Blazek_Radim.pdf>PDF</a>
    (252 kb, presented at Open Source Free Software GIS - <a
    href=http://www.ing.unitn.it/~grass/>GRASS users conference 2002</a>)
-  <li><a href="manuals/">GRASS 5.1 Draft Programmer's Manual</a>
+  <li><a href="manuals/">GRASS 5.7 Draft Programmer's Manual</a>
  <li>
   New <a href="http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass51/doc/vector/vector.html">GRASS
-  5.1 vector API</a> (3D vectors, DBMS support, optional 64bit support)</li>
+  5.7 vector API</a> (3D vectors, DBMS support, optional 64bit support)</li>
 <ul>
  <li>
-  <a href="http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass51/doc/vector/grass51concept.gif">Figure of GRASS 5.1 architecture</a></li>
+  <a href="http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass51/doc/vector/grass51concept.gif">Figure of GRASS 5.7 architecture</a></li>
  <li>
-  <a href="http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass51/doc/vector/grass51atts.gif">Figure of GRASS 5.1 attribute management (native format and PostGIS
+  <a href="http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass51/doc/vector/grass51atts.gif">Figure of GRASS 5.7 attribute management (native format and PostGIS
   support)</a></li>
  <li>
   <a href="http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass51/doc/vector/v.modules.html">GRASS
-  5.1 vector modules upgrade status</a></li>
+  5.7 vector modules upgrade status</a></li>
  </ul>
 </ul>
 <li>Further delopment tasks:
 <ul>
  <li> <i>Outdated:</i> Description of <a href="http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass/documents/grass51milestones.html?rev=1.18.4">GRASS
-     5.1 Milestones: Phase 1 and 2</a></li>
+     5.7 Milestones: Phase 1 and 2</a></li>
  <li> Code cleanup, clones removal, etc.
  <li> GRASS as Web server application (client/server architectures)</li>
  <li> <a href="grass51_vector_discussion.txt">Protocol of a features discussion</a></li>
@@ -152,28 +154,28 @@
 <a name="docs"></a>
-<h2>GRASS 5.1 Documentation</h2>
+<h2>GRASS 5.7 Documentation</h2>
 <ul>
  <li>Manuals: <a href=manuals/html51_user/index.html>HTML</a></li>
- <li><a href=tutorial/index.html>Draft GRASS 5.1 tutorial</a> with examples
+ <li><a href=tutorial/index.html>Draft GRASS 5.7 tutorial</a> with examples
  using the <a href="http://mpa.itc.it/radim/g51/">Sample 3D LOCATION</a></li>
 </ul>
 <a name="downloads"></a>
-<h2>GRASS 5.1.0 Downloads</h2>
+<h2>GRASS 5.7.0 Downloads</h2>
 <ul>
 <li>
 Download <a href="source/snapshot/">CVS snapshot</a> (Note: compilation of
-GRASS 5.1 requires <a href=../grass5/source/snapshot_experimental/>GRASS 5.0 experimental (CVS HEAD) source code</a>!)
+GRASS 5.7 requires <a href=../grass5/source/snapshot_experimental/>GRASS 5.0 experimental (CVS HEAD) source code</a>!)
 </li>
 <li>
 Download <a href="binary/">pre-compiled binaries</a></li>
 <li>
-GRASS 5.1 CVS access:</li>
+GRASS 5.7 CVS access:</li>
 <ul>
 <li>
@@ -186,7 +188,7 @@
 cvs -z3 co grass</li>
 <br>The latter is the experimental GRASS
-5.0 code which is needed (this code is partly linked into GRASS 5.1)</ul>
+5.0 code which is needed (this code is partly linked into GRASS 5.7)</ul>
 <li>
More information about the grass-web mailing list
