[GRASSweb-list]markus: web codemanagement.html,1.11,1.12 data.html,1.30,1.31 download.html,1.52,1.53 firsttime.html,1.31,1.32 grasscvstags.html,1.26,1.27
grass at intevation.de
Fri Sep 12 04:05:10 EDT 2003
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv30935
Modified Files:
codemanagement.html data.html download.html firsttime.html
grasscvstags.html
Log Message:
more 5.1 -> 5.7
Index: codemanagement.html
RCS file: /grassrepository/web/codemanagement.html,v
retrieving revision 1.11
retrieving revision 1.12
diff -u -d -r1.11 -r1.12
--- codemanagement.html 4 Dec 2002 09:08:34 -0000 1.11
+++ codemanagement.html 12 Sep 2003 08:05:08 -0000 1.12
@@ -46,8 +46,9 @@
<li>
The grass51 tree in the CVS is not utilised enough. Developers should have
more courage to just utilise it. As this is clearly a development tree,
-there is no problem to just start away with the new structure. The 5.1.x
-series will lead to the 5.2.x stable line. Until then, developers can reorganise
+there is no problem to just start away with the new structure. The 5.7.x
+series will lead to the 5.8.x stable line (see <a href=roadmap.html>roadmap</a>.
+Until then, developers can reorganise
things as much as they want. All developers interested in progressing grass
and really cleaning it up should just go ahead. We can only learn from
the attempts.</li>
@@ -157,7 +158,7 @@
<tr>
<td>grass51/</td>
-<td>GRASS 5.1</td>
+<td>GRASS 5.7</td>
</tr>
<tr>
Index: data.html
RCS file: /grassrepository/web/data.html,v
retrieving revision 1.30
retrieving revision 1.31
diff -u -d -r1.30 -r1.31
--- data.html 8 Aug 2003 09:52:35 -0000 1.30
+++ data.html 12 Sep 2003 08:05:08 -0000 1.31
@@ -158,8 +158,8 @@
</tr>
<tr>
-<td valign="top"><b>GRASS 5.1</b></td>
-<td valign="top">Sample GRASS 5.1 data with 3D vectors: <a href="http://mpa.itc.it/radim/g51/">Sample
+<td valign="top"><b>GRASS 5.7</b></td>
+<td valign="top">Sample GRASS 5.7 data with 3D vectors: <a href="http://mpa.itc.it/radim/g51/">Sample
3D LOCATION + screenshots</a></td>
<td valign="top"> </td>
Index: download.html
RCS file: /grassrepository/web/download.html,v
retrieving revision 1.52
retrieving revision 1.53
diff -u -d -r1.52 -r1.53
--- download.html 11 Sep 2003 17:30:48 -0000 1.52
+++ download.html 12 Sep 2003 08:05:08 -0000 1.53
@@ -19,7 +19,7 @@
Quick navigation:
<a href="#g50">GRASS 5.0 (stable)</a>
-- <a href="#g51">GRASS 5.1 (exp)</a>
+- <a href="#g57">GRASS 5.7 (exp)</a>
- <a href="#g43">GRASS 4.3 (old)</a>
- <a href="grasscvs.html">CVS</a>
- <a href="#requirements">Requirements</a>
@@ -87,16 +87,16 @@
<tr NOSAVE>
<td BGCOLOR="#33FF33" NOSAVE>
-<a NAME="g51"></a>
-<b>GRASS 5.1.x development tree [experimental]</b></td>
+<a NAME="g57"></a>
+<b>GRASS 5.7.x development tree [experimental]</b></td>
<td BGCOLOR="#33FF33" NOSAVE></td>
</tr>
<tr NOSAVE>
-<td BGCOLOR="#FFFF99" NOSAVE><b><i>Source code 5.1.x</i></b></td>
-<td BGCOLOR="#FFFF66" NOSAVE><b><i>Binaries 5.1.x</i></b></td>
-<td BGCOLOR="#FFCC33" NOSAVE><b><i>Manuals 5.1.x</i></b></td>
+<td BGCOLOR="#FFFF99" NOSAVE><b><i>Source code 5.7.x</i></b></td>
+<td BGCOLOR="#FFFF66" NOSAVE><b><i>Binaries 5.7.x</i></b></td>
+<td BGCOLOR="#FFCC33" NOSAVE><b><i>Manuals 5.7.x</i></b></td>
</tr>
<tr>
Index: firsttime.html
RCS file: /grassrepository/web/firsttime.html,v
retrieving revision 1.32
diff -u -d -r1.31 -r1.32
--- firsttime.html 4 Sep 2003 07:29:23 -0000 1.31
+++ firsttime.html 12 Sep 2003 08:05:08 -0000 1.32
@@ -74,7 +74,7 @@
<li>Maybe you are interested in one of the many GRASS GIS <a href="related_projects.html">related
projects and libraries</a>, such as MapServer, GDAL, PostgreSQL, OGR, libgrass, PROJ4 etc.</a>.
<li>Or have a look at the <a href="nviz/index.html">NVIZ 3-D GRASS Interface</a>.
-<li>Get information about the <a href="grass51/index.html">GRASS 5.1 development</a>.
+<li>Get information about the <a href="grass51/index.html">GRASS 5.7 development</a>.
<li>There also exist many external packages for GRASS called <a href="grass_addons.html">Add-ons</a>.
<li>GRASS as a modular based GIS offers a wide range of possibilites to build professional
solutions. The figure below is an example how grass can be used with other
@@ -97,7 +97,7 @@
external database. In GRASS 5.0
there are drivers for ODBC and PostgreSQL (see the related <a
href=sqlgrasslist.html>GRASS/SQL page</a>).<br>
-In <a href=grass51/index.html>GRASS 5.1</a> it becomes really exciting and
+In <a href=grass51/index.html>GRASS 5.7</a> it becomes really exciting and
also includes native support for DBF files. But
this system is not yet fully implemented.
Index: grasscvstags.html
RCS file: /grassrepository/web/grasscvstags.html,v
retrieving revision 1.26
retrieving revision 1.27
diff -u -d -r1.26 -r1.27
--- grasscvstags.html 15 Apr 2003 08:52:14 -0000 1.26
+++ grasscvstags.html 12 Sep 2003 08:05:08 -0000 1.27
@@ -94,14 +94,14 @@
</ul>
<hr>
-<h2>GRASS 5.1 Experimental: CVS tags</h2>
+<h2>GRASS 5.7 Experimental: CVS tags</h2>
<ul>
-<li>To check out the lastest <b>unstable</b> 5.1 code into a fresh directory, enter:
+<li>To check out the lastest <b>unstable</b> 5.7 code into a fresh directory, enter:
<p>
<tt>cvs -z3 checkout grass51</tt>
<p>
-Note that you also need the latest <b>unstable</b> 5.0.x code to compile 5.1.x.
+Note that you also need the latest <b>unstable</b> 5.3.x code to compile 5.7.x.
</ul>
More information about the grass-web
