[GRASSweb-list]using png for konqueror created with convert
Bernhard Reiter
bernhard at intevation.de
Mon Sep 15 09:15:40 EDT 2003
On Mon, Sep 15, 2003 at 02:35:10PM +0200, Markus Neteler wrote:
> On Mon, Sep 15, 2003 at 02:14:08PM +0200, Bernhard Reiter wrote:
> > On Mon, Sep 15, 2003 at 01:49:28PM +0200, grass at intevation.de wrote:
> > > Author: markus
> > > Update of /grassrepository/web
> > > In directory doto:/tmp/cvs-serv12794
> > > Modified Files:
> > > roadmap.html
> > > Log Message:
> > > color cosmetics to match version box in index.html, changed to JPG
> > > as konqueror doesn't like the PNG from Imagemagic 'convert'
> > I'm against using JPG for this, it is the wrong format for the task.
> Even I don't like it. But GIF ... :-((
Yes, GIF would be worse.
> > This is a bug in convert.
> Maybe.
> > I used convert from
> > Debian GNU/Linux imagemagick Version: 4:5.4.4.5-1woody1
> > (Version: @(#)ImageMagick 5.4.4 04/05/02 Q:16)
> convert -v
> Version: ImageMagick 5.5.2 12/01/02 Q16 http://www.imagemagick.org
> Copyright: Copyright (C) 2002 ImageMagick Studio LLC
Well, yours is newer than mine
Maybe that is a bug in konqueror or openoffice.
However we should find out and report it,
because it is possible to use some pngs.
> > And could create a png understandable for konqueror (from KDE 3.1.2)
> > without problems.
> > How did you create the roadmap?
> OpenOffice1.1 -> PNG
So you don't need convert at all to get the wanted PNG?
It might be an open office bug then?
You could try gimp to get the image you need.
> To get "convert" updated here is sort of difficult (and I am not root
> on my machine and don't want to compile ImageMagick myself).
Not necessary I guess.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-web/attachments/20030915/6c54637e/attachment.bin
More information about the grass-web
