[GRASSweb-list]markus: web data.html,1.33,1.34
grass at intevation.de
Tue Apr 27 09:03:27 EDT 2004
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv16071
Modified Files:
data.html
Log Message:
added Spearfish packages for 5.3 and 5.7
Index: data.html
RCS file: /grassrepository/web/data.html,v
retrieving revision 1.33
retrieving revision 1.34
diff -u -d -r1.33 -r1.34
--- data.html 11 Feb 2004 20:29:47 -0000 1.33
+++ data.html 27 Apr 2004 13:03:25 -0000 1.34
@@ -3,7 +3,7 @@
<head>
<DEFANGED_meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<DEFANGED_link rel="stylesheet" type="text/css" href="sitestyle.css">
- <DEFANGED_meta name="Author" content="GRASS Development Team/MN">
+ <DEFANGED_meta name="Author" content="GRASS Development Team/Markus Neteler">
<title>GRASS Datasets</title>
</head>
<body>
@@ -28,10 +28,10 @@
<td valign="top"><b>External related data sets</b></td>
</tr>
<tr>
- <td valign="top"><b>GRASS 5.0.x</b></td>
- <td valign="top"><a href="sampledata/spearfish_grass50data.tar.gz">SPEARFISH
+ <td valign="top"><b>GRASS 5.0</b></td>
+ <td valign="top"><a href="sampledata/spearfish_grass50data.tar.gz">SPEARFISH 5.0
data set</a> (9.7MB size) - contains raster, vector and point data of South
- Dakota [fixed some roads vector types and soils topology 2/2003]
+ Dakota [<a href="sampledata/spearfish50_history.txt">change history</a>]<br>
(UTM projection, Clarke66 ellipsoid, NAD27 conus)</td>
<td valign="top">
<ul>
@@ -59,7 +59,26 @@
</ul></td>
</tr>
<tr>
-<td valign="top"> </td>
+<td valign="top"><b>GRASS 5.3</b></td>
+<td valign="top"><a href="sampledata/spearfish_grass53data.tar.gz">SPEARFISH 5.3
+ data set</a> (22MB size) - contains raster, vector and point data of South
+ Dakota [<a href="sampledata/spearfish53_history.txt">change history</a>]<br>
+ (UTM projection, Clarke66 ellipsoid, NAD27 conus)</td>
+<td valign="top"><i>see above</i></td>
+</tr>
+<tr>
+<td valign="top"><b>GRASS 5.7</b></td>
+<td valign="top"><a href="sampledata/spearfish_grass57data.tar.gz">SPEARFISH 5.7
+ data set</a> (20MB size) - contains raster, vector and point data of South
+ Dakota [<a href="sampledata/spearfish57_history.txt">change history</a>]<br>
+</tr>
+<tr>
+<td valign="top"><b>GRASS 5.0-5.7</b></td>
<td valign="top"><a href="sampledata/imagery_grassdata.tar.gz">IMAGERY
data set</a> (19.1MB size) - belongs to SPEARFISH, contains aerial and SPOT
images, xy LOCATION, data from the 80's [file structure cleaned 1/2002]</li>
@@ -72,10 +91,11 @@
<td valign="top"><ul>
<li><a href="ftp://ftp.glcf.umiacs.umd.edu/glcf/Landsat/WRS2/p033/r029/">Related
free LANDSAT-TM5 / LANDSAT-7 ETM+ data</a> collected by <a
-href=http://glcfapp.umiacs.umd.edu>University of Maryland</a></td>
-</tr>
+href=http://glcfapp.umiacs.umd.edu>University of Maryland</a></ul>
+</td></tr>
<tr>
+<td valign="top"><b>GRASS 5.0.x</b></td>
<td valign="top"><a href="sampledata/global_grass5data.tar.gz">Global
data set</a> (1.1 Mb size) - a small global data set (nations, soils, vegetation,
coastlines, lat./long projection, from 1985)</td>
@@ -92,7 +112,7 @@
</ul></td>
</tr>
<tr>
<td valign="top"><a href="sampledata/ansi_grass5_agnps.tar.gz">AGNPS 5.0
erosion model data set</a></b> (66 kb size) (location: ansi, mapset: PERMANENT)</td>
@@ -102,7 +122,7 @@
</tr>
<tr>
<td valign="top"><a href="sampledata/fire_grassdata.tar.gz">Fire
simulation data set</a> (145kb size) - sample data for r.ros, r.spread,
and r.spreadpath fire simulation modules. Get demo script: <a href="sampledata/firedemo.sh">firedemo.sh</a>
@@ -111,14 +131,14 @@
</tr>
<tr>
<td valign="top"><a href="grid3d/index.html#sample">3D
raster voxel sample data</a></b> to test the 3D-environment</td>
</tr>
<tr>
<td valign="top"><a href="http://mpa.itc.it/grasstutor/data_menu.phtml">LIDAR, erosion data sets
- sample data from the book "Open Source GIS: A GRASS GIS Approach"</a></td>
@@ -126,6 +146,15 @@
</tr>
<tr>
+<td valign="top">Sample GRASS 5.7 data with 3D vectors: <a href="http://mpa.itc.it/radim/g51/">Sample
+3D LOCATION + screenshots</a></td>
+<td valign="top"> </td>
+</tr>
+<tr>
<td valign="top"><b>GRASS 4.x (old)</b></td>
<td valign="top"><a href="sampledata/spearfish_grass4data.tar.gz">SPEARFISH
data set</a> (6.8MB size) - contains raster, vector and point data of South
@@ -134,7 +163,7 @@
<td valign="top"> (see related 5.0 entry)</td>
</tr>
<tr>
+<td valign="top"><b>GRASS 4.x (old)</b></td>
<td valign="top"><a href="sampledata/global_grass4data.tar.gz">Global
data set</a> (979kb size) - a small global data set (nations, soils,
vegetation, coastlines, lat./long projection, from 1985)</td>
@@ -142,7 +171,7 @@
</tr>
<tr>
<td valign="top"><a href="sampledata/etopo5_grassdata.tar.gz">ETOPO5
elevation model</a> (1.8MB size) - global raster elevation model.
5min grid, WGS84 projection</td>
@@ -153,20 +182,14 @@
</ul></td>
</tr>
<tr>
<td valign="top"><a href="sampledata/agnps_grassdata.tar.gz">AGNPS 5.0
erosion model data set</a></b> (45 kb size) (location: ansi, mapset: PERMANENT)</td>
</tr>
-<tr>
-<td valign="top"><b>GRASS 5.7</b></td>
-<td valign="top">Sample GRASS 5.7 data with 3D vectors: <a href="http://mpa.itc.it/radim/g51/">Sample
-3D LOCATION + screenshots</a></td>
-</tr>
</table>
<h2>Further external GIS data sets in various formats</h2>
@@ -279,7 +302,7 @@
<!-- FOOTER -->
<hr>
-<DIV ALIGN=right>© 1999-2003 GRASS Development Team<br>
+<DIV ALIGN=right>© 1999-2004 GRASS Development Team<br>
<a href="mailto:weblist at grass.itc.it">Comments</a> about this page | <a href="faq/index.html">FAQ</a> | <a href="download.html">Download</a> | <a href="support.html">Support</a> | <a href="gdp/index.html">Docs</a> | <a href="grassdevel.html">Programming</a> | Back <a href=index.html>HOME</a><br>
<i>Last change:
$Date$
More information about the grass-web
