[GRASSweb-list]markus: web/grass53/binary/mswindows_cygwin README.html,1.1,1.2
grass at intevation.de
Fri Aug 13 07:36:36 EDT 2004
Author: markus
Update of /grassrepository/web/grass53/binary/mswindows_cygwin
In directory doto:/tmp/cvs-serv24276
Modified Files:
README.html
Log Message:
updated
Index: README.html
RCS file: /grassrepository/web/grass53/binary/mswindows_cygwin/README.html,v
retrieving revision 1.1
retrieving revision 1.2
diff -u -d -r1.1 -r1.2
--- README.html 29 Jun 2004 14:01:23 -0000 1.1
+++ README.html 13 Aug 2004 11:36:33 -0000 1.2
@@ -10,31 +10,29 @@
href=http://sources.redhat.com/cygwin/>cygwin</a>.
<h3>Installation:</h3>
-<ol>
- <li>get the file <br>
-grass5.3-cvs_arch-bin.tar.gz</li>
- <li>get the installation script <br>
-grass5.3-cvs_arch-install.sh</li>
-</ol>
-<h4>where</h4>
-<ul>
- <li>arc is the architecture of your platform (e.g. pc-linux-gnu)</li>
-</ul>
-<br>
-For installation, run the install script with --help option:<br>
-<ul>
- <li>sh grass5.3-cvs_arch-install.sh --help </li>
-or <li>./grass5.3-cvs_arch-install.sh --help </li>
-</ul>
-<br>
-Or without help, directly:<br>
-<ul>
- <li>sh grass5.3-cvs_arch-install.sh grass5.3-cvs_arch-bin.tar.gz</li>
-or
- <li>./grass5.3-cvs_arch-install.sh grass5.3-cvs_arch-bin.tar.gz</li>
-</ul>
+These are experimental Cygwin binaries compiled using the new shared library
+support in GRASS 5.3.0 to create shared Windows DLLs. They also include
+shared DLL versions of the GDAL 1.2.0 and PROJ.4.4.8 libraries. This results
+in a (relatively) small binary package size, around 13-14MB.
+<p>
+Run 'sh grass5.3.0_i586-pc-cygwin_install.sh' to see the install options.
+<p>
+To use tcltkgrass, you must un-install the Cygwin Tcl/Tk and install the
+X-Windows Tcl/Tk Cygwin binaries that are available on the GRASS website
+(file xtcltk-8.3.4-CYGWIN.tar.gz in this directory).
+You should also run X-Windows in full screen mode using its own window
+manager. Tcltkgrass and NVIZ will not operate correctly using the Windows
+window manager.
+<p>
+All of the binaries except NVIZ were compiled on a MS-Windows 2000 machine with
+compiler flags set to optimise for a Pentium processor. The NVIZ binary is
+a slightly older version that was compiled successfully by Glynn Clements on
+Windows 98 and was formerly available on the GRASS website.
+<p>
+Paul Kelly<br>
+paul-gras AT stjohnspoint.co.uk (comments and complaints here please)
+<P>
<hr>Please help us and report bugs.<br>
<a href="http://grass.itc.it/bugtracking/bugreport.html">Bug report form</a>
</body>
More information about the grass-web
