[GRASSweb-list]markus: web/grass57/binary/macosx README.html,1.1,1.2
grass at intevation.de grass at intevation.de
Mon Aug 16 09:45:04 EDT 2004
Author: markus
Update of /grassrepository/web/grass57/binary/macosx
In directory doto:/tmp/cvs-serv3752/macosx
Modified Files:
	README.html
Log Message:
page cosmetics
Index: README.html
RCS file: /grassrepository/web/grass57/binary/macosx/README.html,v
retrieving revision 1.1
retrieving revision 1.2
diff -u -d -r1.1 -r1.2
--- README.html	10 Oct 2003 15:48:37 -0000	1.1
+++ README.html	16 Aug 2004 13:45:02 -0000	1.2
@@ -4,9 +4,9 @@
 This directory contains the Mac OSX binary code for
 GRASS 5.7.x EXPERIMENTAL in gzipped tar format.
-<b>Note that this binary version may not work.
-   Use at your own risk.</b>
+<b>Note: Occasionally, weekly snapshots may not work properly;
+   in case, please revert to a previous version.</b>
+<P>
 Installation:
 1. get the file
@@ -15,8 +15,7 @@
 2. get the installation script
      grass57-DD-MM-YYYY-arch-install.sh
-Note: this code is highly experimental and may be malfunctioning.<br>
-For installation, run the install script with --help option:
+<P>For installation, run the install script with --help option:
      grass57-DD-MM-YYYY-arch-install.sh --help
More information about the grass-web mailing list
