[GRASSweb-list]markus: web/grass57 index.html,1.74,1.75
grass at intevation.de
Wed Aug 18 08:34:23 EDT 2004
Author: markus
Update of /grassrepository/web/grass57
In directory doto:/tmp/cvs-serv12420/grass57
Modified Files:
Log Message:
documented LFS
Index: index.html
RCS file: /grassrepository/web/grass57/index.html,v
retrieving revision 1.74
retrieving revision 1.75
diff -u -d -r1.74 -r1.75
--- index.html 7 Aug 2004 14:15:04 -0000 1.74
+++ index.html 18 Aug 2004 12:34:21 -0000 1.75
@@ -124,6 +124,12 @@
<P>
The officially released source code packages contain <b>all required code</b>.
+<h2>Large File Support</h2>
+GRASS 5.7 supports reading and writing large files (> 2GB)
+if it is possible in your operating system. If you compile with
+<tt>-D_FILE_OFFSET_BITS=64</tt>, you should be able to have raster maps
+which are larger than 2Gb.
<a name="downloads"></a>
<h2>GRASS 5.7.0 Downloads</h2>
More information about the grass-web
