[GRASSweb-list]hamish: web/grass57/tutorial ex_basic.html,1.18,1.19
grass at intevation.de
Mon Dec 6 18:55:49 EST 2004
Author: hamish
Update of /grassrepository/web/grass57/tutorial
In directory doto:/tmp/cvs-serv25470/web/grass57/tutorial
Modified Files:
ex_basic.html
Log Message:
remove old -a flag from d.what.vect example (bug #2799)
Index: ex_basic.html
RCS file: /grassrepository/web/grass57/tutorial/ex_basic.html,v
retrieving revision 1.18
retrieving revision 1.19
diff -u -d -r1.18 -r1.19
--- ex_basic.html 1 Jun 2004 01:56:49 -0000 1.18
+++ ex_basic.html 6 Dec 2004 23:55:47 -0000 1.19
@@ -224,8 +224,8 @@
#Then check connection:
v.db.connect -p markveggy.1
-#Query new map with attributes:
-d.what.vect -a
+#Query new map:
+d.what.vect
#Or you can display with labels attached to the vector: First we check
# from which column labels to display:
More information about the grass-web
