[GRASSweb-list]markus: web/download data.inc,1.1,1.2
grass at intevation.de
Mon Dec 27 15:35:14 EST 2004
Author: markus
Update of /grassrepository/web/download
In directory doto:/tmp/cvs-serv4439
Modified Files:
data.inc
Log Message:
fixed urls
Index: data.inc
RCS file: /grassrepository/web/download/data.inc,v
retrieving revision 1.1
retrieving revision 1.2
diff -u -d -r1.1 -r1.2
--- data.inc 19 Dec 2004 16:42:08 -0000 1.1
+++ data.inc 27 Dec 2004 20:35:12 -0000 1.2
@@ -12,19 +12,19 @@
</tr>
<tr>
<td valign="top"><b>GRASS 5.0</b></td>
- <td valign="top"><a href="sampledata/spearfish_grass50data.tar.gz">SPEARFISH 5.0
+ <td valign="top"><a href="../sampledata/spearfish_grass50data.tar.gz">SPEARFISH 5.0
data set</a> (9.7MB size) - contains raster, vector and point data of South
- Dakota [<a href="sampledata/spearfish50_history.txt">change history</a>]<br>
+ Dakota [<a href="../sampledata/spearfish50_history.txt">change history</a>]<br>
(UTM projection, Clarke66 ellipsoid, NAD27 conus)</td>
<td valign="top">
<ul>
- <li><a href="gdp/tutorial/spearDB.ps.gz">Short data set documentation</a></li>
- <li>A few <a href="sampledata/spearfish_docs_1979_p163to171.tar.gz">SPEARFISH
+ <li><a href="../gdp/tutorial/spearDB.ps.gz">Short data set documentation</a></li>
+ <li>A few <a href="../sampledata/spearfish_docs_1979_p163to171.tar.gz">SPEARFISH
data soils related documents</a></li>
- <li>Read also <a href="gdp/tutorial/grass41/">Chapter 5</a> of John Parks GRASS 4.0 tutorial (ch5a.ps)</li>
+ <li>Read also <a href="../gdp/tutorial/grass41/">Chapter 5</a> of John Parks GRASS 4.0 tutorial (ch5a.ps)</li>
<li>See this <a href="http://www.udel.edu/johnmack/frec682/">online
GRASS course</a> from John Mackenzie</li>
- <li>Get the <a href="sampledata/soils_legend.txt">legend
+ <li>Get the <a href="../sampledata/soils_legend.txt">legend
for soils map</a></li>
</ul>
</td>
@@ -32,7 +32,7 @@
<ul>
<li> DLGs: <a href="http://edc.usgs.gov/geodata/dlg_large/states/SD.html">Related DLG South Dakota data from USGS</a> (select
"SPEARFISH" and "Deadwood North")
- <li> DRGs: <a href="sampledata/spearfish_toposheet.tar.gz">Related
+ <li> DRGs: <a href="../sampledata/spearfish_toposheet.tar.gz">Related
South Dakota topo sheets from SDGS, GeoTIFF, NAD27, 4.7MB</a> (ref: <a href="http://www.sdgs.usd.edu/register/index.html">data source</a>
(select Lawrence County, quadrangles "Spearfish" and "Deadwood North", orig. data in WGS84)</li>
<li><a href="http://www.gisdatadepot.com/catalog/US/61050/326/index.html">Related
@@ -43,18 +43,18 @@
</tr>
<tr>
<td valign="top"><b>GRASS 5.3</b></td>
-<td valign="top"><a href="sampledata/spearfish_grass53data.tar.gz">SPEARFISH 5.3
+<td valign="top"><a href="../sampledata/spearfish_grass53data.tar.gz">SPEARFISH 5.3
data set</a> (22MB size) - contains raster, vector and point data of South
- Dakota [<a href="sampledata/spearfish53_history.txt">change history</a>]<br>
+ Dakota [<a href="../sampledata/spearfish53_history.txt">change history</a>]<br>
<td valign="top"><i>see above</i></td>
</tr>
<tr>
<td valign="top"><b>GRASS 5.7</b></td>
-<td valign="top"><a href="sampledata/spearfish_grass57data.tar.gz">SPEARFISH 5.7
+<td valign="top"><a href="../sampledata/spearfish_grass57data.tar.gz">SPEARFISH 5.7
data set</a> (20MB size) - contains raster, vector and point data of South
- Dakota [<a href="sampledata/spearfish57_history.txt">change history</a>]<br>
+ Dakota [<a href="../sampledata/spearfish57_history.txt">change history</a>]<br>
@@ -62,13 +62,13 @@
<tr>
<td valign="top"><b>GRASS 5.0-5.7</b></td>
-<td valign="top"><a href="sampledata/imagery_grassdata.tar.gz">IMAGERY
+<td valign="top"><a href="../sampledata/imagery_grassdata.tar.gz">IMAGERY
data set</a> (19.1MB size) - belongs to SPEARFISH, contains aerial and SPOT
images, xy LOCATION, data from the 80's [file structure cleaned 1/2002]</li>
</ul></td>
<td valign="top">
<ul>
- <li><a href="gdp/imagery/imagery.ps.gz">Transformation
+ <li><a href="../gdp/imagery/imagery.ps.gz">Transformation
documentation</a> and usage of imagery modules.</li>
</ul></td>
<td valign="top"><ul>
@@ -79,7 +79,7 @@
<tr>
<td valign="top"><b>GRASS 5.0.x</b></td>
-<td valign="top"><a href="sampledata/global_grass5data.tar.gz">Global
+<td valign="top"><a href="../sampledata/global_grass5data.tar.gz">Global
data set</a> (1.1 Mb size) - a small global data set (nations, soils, vegetation,
coastlines, lat./long projection, from 1985)</td>
@@ -97,10 +97,10 @@
</tr>
<tr>
-<td valign="top"><a href="sampledata/ansi_grass5_agnps.tar.gz">AGNPS 5.0
+<td valign="top"><a href="../sampledata/ansi_grass5_agnps.tar.gz">AGNPS 5.0
erosion model data set</a></b> (66 kb size) (location: ansi, mapset: PERMANENT)</td>
-<li> <a href=gdp/erosion/agnps/agnps.html>GRASS/AGNPS info page</a></li>
+<li> <a href=../gdp/erosion/agnps/agnps.html>GRASS/AGNPS info page</a></li>
</ul>
</td>
<td valign="top"> </td>
@@ -108,9 +108,9 @@
<tr>
-<td valign="top"><a href="sampledata/fire_grassdata.tar.gz">Fire
+<td valign="top"><a href="../sampledata/fire_grassdata.tar.gz">Fire
simulation data set</a> (145kb size) - sample data for r.ros, r.spread,
-and r.spreadpath fire simulation modules. Get demo script: <a href="sampledata/firedemo.sh">firedemo.sh</a>
+and r.spreadpath fire simulation modules. Get demo script: <a href="../sampledata/firedemo.sh">firedemo.sh</a>
(run within fire simulation data set)</td>
@@ -127,7 +127,7 @@
<tr>
<td valign="top"><a href="http://mpa.itc.it/grasstutor/data_menu2nd.phtml">Slovakia 3D precipitation data set</a>
-- <a href=sampledata/slovakia3d_readme.txt>README</a></td>
+- <a href=../sampledata/slovakia3d_readme.txt>README</a></td>
<td valign="top">3D sample data (vector, volume) from the book
<a href="http://mpa.itc.it/grassbook2/">Open Source GIS: A GRASS GIS Approach, 2nd Edition</a></td>
@@ -144,7 +144,7 @@
<tr>
<td valign="top"><b>GRASS 4.x (old)</b></td>
-<td valign="top"><a href="sampledata/spearfish_grass4data.tar.gz">SPEARFISH
+<td valign="top"><a href="../sampledata/spearfish_grass4data.tar.gz">SPEARFISH
data set</a> (6.8MB size) - contains raster, vector and point data of South
Dakota (UTM projection)</td>
<td valign="top"> (see related 5.0 entry)</td>
@@ -152,7 +152,7 @@
</tr>
<tr>
-<td valign="top"><a href="sampledata/global_grass4data.tar.gz">Global
+<td valign="top"><a href="../sampledata/global_grass4data.tar.gz">Global
data set</a> (979kb size) - a small global data set (nations, soils,
vegetation, coastlines, lat./long projection, from 1985)</td>
@@ -160,7 +160,7 @@
</tr>
<tr>
-<td valign="top"><a href="sampledata/etopo5_grassdata.tar.gz">ETOPO5
+<td valign="top"><a href="../sampledata/etopo5_grassdata.tar.gz">ETOPO5
elevation model</a> (1.8MB size) - global raster elevation model.
5min grid, WGS84 projection</td>
@@ -171,7 +171,7 @@
</tr>
<tr>
-<td valign="top"><a href="sampledata/agnps_grassdata.tar.gz">AGNPS 5.0
+<td valign="top"><a href="../sampledata/agnps_grassdata.tar.gz">AGNPS 5.0
erosion model data set</a></b> (45 kb size) (location: ansi, mapset: PERMANENT)</td>
More information about the grass-web
