[GRASSweb-list]markus: web/grass51 index.html,1.65,1.66
grass at intevation.de grass at intevation.de
Thu Feb 12 04:14:08 EST 2004
Author: markus
Update of /grassrepository/web/grass51
In directory doto:/tmp/cvs-serv27094/grass51
Modified Files:
Log Message:
some updates
Index: index.html
RCS file: /grassrepository/web/grass51/index.html,v
retrieving revision 1.65
retrieving revision 1.66
diff -u -d -r1.65 -r1.66
--- index.html	2 Dec 2003 16:03:37 -0000	1.65
+++ index.html	12 Feb 2004 09:14:06 -0000	1.66
@@ -31,8 +31,8 @@
 [GRASS 5.1 renamed to GRASS 5.7, Sep 11 2003, see <a href="../roadmap.html">roadmap</a>] <P>
-GRASS 5.7 is currently under development. It is neither complete (it still
-contains only a few modules) nor it is intended to productional usage.
+GRASS 5.7 is currently under development. It is not complete yet nor it is intended
+to productional usage. But it's in a fairly good state now.
 Development releases are provided for people who want to help test, debug,
 and improve GRASS 5.7. Knowing this, please read on. The modules already
 present in this version can be seen <a href="manuals/html57_user/index.html">here</a>
@@ -55,7 +55,7 @@
   href=http://www.rcost.unisannio.it/antoniol/students/PostGrass/>read
   documentation</a> (and <a href=http://postgis.refractions.net/>here</a> is
   the PostGIS site), allows for multiuser write access</li>
- <li><b>spatial index</b> - v.build (v.support) accelerated from hours to
+ <li><b>spatial index</b> - v.build (was: v.support) accelerated from hours to
   seconds</li>
 </ul>
@@ -74,7 +74,7 @@
  layers and may be linked to one or several external tables</li>
  <li>
- <b>3D vectors</b> may be created (see <a
+ <b>2D/3D vectors</b> may be created (see <a
   href=http://mpa.itc.it/radim/g51/chaloupky1.png>screenshot</a>)
  (eg TINs), already supported in NVIZ</li>
@@ -82,7 +82,7 @@
   forms library implemented for user friendly query dialogs</li>
  <li>
-  Linear reference systems supported</li>
+  Linear reference systems supported (LRS, to come)</li>
 </ul>
 <li>Applications/Misc:
@@ -149,6 +149,10 @@
  <li> GRASS as Web server application (client/server architectures)</li>
  <li> <a href="grass51_vector_discussion.txt">Protocol of a features discussion</a></li>
 </ul>
+<li><a href=http://mpa.itc.it/radim/grass++/index.html>GRASS++ library</a>: GRASS++ is experimental C++ open source library,
+    which may be used in C++ programs, to access GRASS data. Currently GRASS++ contains only few
+    classes for basic setup and GRASS 5.7 raster and vector reading. Used for example in the
+    <a href=http://mpa.itc.it/radim/qgis/index.htmlGRASS/QGIS> integration</a>.
 <li> Feel free to contact and join the <a href="../grassdevel.html">GRASS Development Team</a>!
 </ul>
More information about the grass-web mailing list
