[GRASSweb-list]scott: web/macgrass macgrass.html,1.2,1.3
grass at intevation.de grass at intevation.de
Thu Feb 12 15:30:31 EST 2004
Author: scott
Update of /grassrepository/web/macgrass
In directory doto:/tmp/cvs-serv19205
Modified Files:
	macgrass.html
Log Message:
updates to URLs, tidying
Index: macgrass.html
RCS file: /grassrepository/web/macgrass/macgrass.html,v
retrieving revision 1.2
retrieving revision 1.3
diff -u -d -r1.2 -r1.3
--- macgrass.html	11 Feb 2004 00:53:06 -0000	1.2
+++ macgrass.html	12 Feb 2004 20:30:28 -0000	1.3
@@ -1,257 +1 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-  <DEFANGED_meta content="text/html; charset=iso-8859-1"
- http-equiv="Content-Type">
-  <DEFANGED_meta content="Scott Mitchell" name="Author">
-  <DEFANGED_meta content="GRASS, GIS, Macintosh" name="KeyWords">
-  <DEFANGED_link href="sitestyle.css" type="text/css" rel="stylesheet">
-  <title>GRASS GIS 5.0 on Macintosh Information</title>
-</head>
-<body>
-<center>
-<h1>
-<hr width="100%" noshade="noshade" size="3">GRASS
-5 on Mac OS X</h1>
-(DRAFT version - Feb 5, 2004)<br>
-<br>
-</center>
-<p>
-</p>
-<h1>GRASS GIS on Mac OS X<br>
-</h1>
-GRASS on Mac OS X shares all the functionality enjoyed on other UNIX-
-or Linux-based platforms.&nbsp; There are quirks to the operating
-system that occasionally pose challenges when new features are added or
-changed in the GRASS source code, but these are usually sorted out
-promptly.&nbsp; In
-addition, due to the fact that Mac OS X has evolved quite differently
-from other UNIX systems, there is a variety of ways to get GRASS
-installed on a Mac.&nbsp; This page is an attempt to help you navigate
-through the options.&nbsp; Some assumptions are made about your
-familiarity with GRASS, in that we are not re-explaining things here
-that are found in other pages on the GRASS web site.<br>
-<br>
-<br>
-<h1>UNIX/X11-based or Aqua-based ?<br>
-</h1>
-The first main decision we'll discuss is whether or not GRASS uses
-features that are exclusive to Apple's graphic interface
-("Aqua").&nbsp; This allows more seamless integration in to the Apple
-environment, but requires work "outside" of the main GRASS development
-to make it work.&nbsp; If you are familiar with the <a
- href="www.r-project.org">R statistics package</a>, this may be
-familiar - there have long been projects alongside the main development
-to enhance R by using capabilities of the Mac environment.&nbsp; For
-GRASS, such work has been concentrated in the efforts of Joshua
-Lecock's <a href="http://openosx.com/grass/">Open OS X port of GRASS</a>,
-which uses an Aqua version of the Tcl/Tk interface so that the menuing
-system has a consistent look and feel to other Macintosh
-products.&nbsp; It also provides a software installation CD,
-subscription and support options, and various bundles with other
-traditonally-UNIX software packages. <br>
-<br>
-The alternative approach is to stick with the X11 interface that is
-shared amongst other UNIX systems, in which case GRASS will look and
-behave pretty much the same as on other platforms.&nbsp; In the past,
-this required the user to have X11 from another source installed and
-running properly, but now (as of OS 10.3 "Panther") Apple includes X11
-with the operating system, combining XFree86 with a window manager that
-is
-integrated with the Aqua graphics system.&nbsp; So if you have this
-version of the operating system, the windows that you run GRASS in can
-now all be part of the normal Mac windowing system, although if you
-want the graphical menuing system (which is an optional way to run
-GRASS), it will use standard X11-based Tcl/Tk, and requires that you
-have that installed separately (GRASS does not provide it).&nbsp; If
-you are still using OS 10.2 ("Jaguar"), you can install X11 separately
-a number of ways (see below).<br>
-<br>
-<h1>Prerequisites</h1>
-All platforms require a number of external packages to make GRASS work,
-either at all, or to its full potential.&nbsp; Some of these are
-provided in a base Mac OS X system (the number of which has gone up
-over time), whereas others are easily available as downloaded binaries
-or source code.&nbsp; The requirements for compiling the software
-yourself are more complicated and are discussed first.&nbsp; If you are
-going to install pre-compiled binaries you can skip to the "Binaries"
-section of this document.<br>
-<br>
-<span DEFANGED_STYLE="text-decoration: underline;"><span
- DEFANGED_STYLE="font-weight: bold;">Requirements to compile GRASS:</span></span><br>
-<br>
-If you are going to do any compiling of software, you will need the
-development tools, available free from Apple.&nbsp; This package was
-called Development Tools for OS X versions 10.0-10.2, and "Xcode tools"
-when 10.3 ("Panther") was released.&nbsp; It is on a separate install
-CD in the Panther package and either on CD or available for download
-for earlier versions.<br>
-<br>
-The general prerequisites for all platforms are listed in the <a
- href="http://grass.ibiblio.org/grass5/source/REQUIREMENTS.html">GRASS
-requirements page</a>.&nbsp; Of these, all of the aboslutely required
-elements (e.g. the compiler/build system) are provided by Apple.&nbsp;
-As discussed above, the X11 window system is provided by Apple as an
-optional install starting in OS X 10.3.&nbsp; For Mac OS X 10.2 (or
-earlier), you can install XFree86 using the <a
- href="http://fink.sourceforge.net">fink</a> or <a
- href="http://darwinports.opendarwin.org">DarwinPorts</a> package
-manager systems, or compile it yourself from source.<br>
-<br>
-The package manager systems are an easy way to find, compile where
-necessary, and install ports of unix software on to a Mac OS X
-system.&nbsp; If you have used Cygwin on a Windows machine, or RedHat,
-Debian, etc. on a Linux machine, you are probably already aware of
-their package managers.&nbsp; On the Mac, you can choose from at least <a
- href="http://darwinports.opendarwin.org">DarwinPorts</a> (are there
-more?).&nbsp; Fink uses the same tools as Debian Linux (apt-get,
-dpkg).&nbsp; DarwinPorts is more similar to the FreeBSD Ports
-project.&nbsp; The initial author of this document chose fink because I
-was already used to Debian, but others have also reported satisfaction
-with DarwinPorts.&nbsp; You should read the web pages for those two
-projects to learn about the differences between them, and how to
-install and use them.<br>
-<br>
-<span DEFANGED_STYLE="font-weight: bold; text-decoration: underline;">Optional
-requirements </span><span DEFANGED_STYLE="text-decoration: underline;">(as
-listed in the </span><span
- DEFANGED_STYLE="font-weight: bold; text-decoration: underline;"> <a
-requirements page</a>)</span><span DEFANGED_STYLE="font-weight: bold;"><span
- DEFANGED_STYLE="text-decoration: underline;">:</span><br>
-<br>
-</span>As of OS X version 10.3, Apple provides suitable versions of
-FreeType 2 and OpenGL (if you have the Apple X11 installed).<br>
-<br>
-The rest of the optional requirements can be downloaded as source and
-compiled "manually", or installed with either of the package management
-systems (is this true of all the packages in DarwinPorts?).&nbsp; In
-fink, the packages you would need are:&nbsp; libtiff libtiff-shlibs
-libpng3 libpng3-shlibs libjpeg libjpeg-shlibs tcltk tcltk-dev
-tcltk-shlibs gd2 gd2-shlibs <span DEFANGED_STYLE="font-style: italic;">gdal
-gdal-dev gdal-shlibs</span> (but see special note re: GDAL below)
-netpbm netpbm-shlibs postgresql postgresql73-dev unixodbc2
-unixodbc2-dev, and&nbsp; r-base (for the R language link to GRASS -
-note that this installs the X11/UNIX version of R, not the Aqua
-version).&nbsp;&nbsp; <br>
-<br>
-<span DEFANGED_STYLE="font-weight: bold;">GDAL</span> deserves special mention,
-because the version that is generally available either as "released"
-source code, or as a fink package as of this writing is quite far
-behind the current development version, and it is the current versions
-of GDAL that are used in GRASS development.&nbsp; This tool and its use
-in GRASS is updated quite frequently, therefore if you don't have the
-most recent version of GDAL when you are trying to compile GRASS,
-there's a good chance that r.in.gdal compilation will fail, or that the
-tool will not work as expected.&nbsp; Therefore it is recommended that
-you install a relatively recent binary version of GDAL (e.g. <a
- href="http://wwwamb.bologna.enea.it/forgrass">http://wwwamb.bologna.enea.it/forgrass</a>
-)or compile from a recent version of the <a
- href="http://www.remotesensing.org/gdal/">sources available via
-anonymous CVS</a>.&nbsp; The r.in.gdal command is extremely useful for
-importing a wide variety of spatial data formats, so it is worthwhile
-spending the extra effort to get this working if you will have any data
-import tasks.<br>
-<br>
-<br>
- DEFANGED_STYLE="font-weight: bold;">Binary releases of GRASS for Mac OS X</span></span><br>
-<br>
-When binary packages are constructed, reasonable efforts are made to
-package everything you need into a single download and install
-process.&nbsp; For example, the GDAL library discussed above is
-normally included.&nbsp; Some of the other GRASS modules that interface
-with other software packages will require separate installations for
-normal functionality.&nbsp; Such external packages include PostgreSQL
-(for the PostgreSQL database interface), Unix ODBC (for the ODBC
-database interface), and Tcl/Tk 8.x (for the graphical menu system and
-the NVIZ visualization tool).&nbsp; In addition, the Tcl/Tk is
-version-sensitive, therefore your installation version will need to
-match that used by the person that made the binaries (is this
-accurate?).&nbsp; (ASK OTHERS - it may be true now that only GDAL, X11,
-and tcltk are needed for binaries to work?)<br>
-<br>
-Note that the package managers discussed in the above section on
-installing from source code can also be useful for installing these
-extra software packages.&nbsp; In some cases they will allow you to
-stick with "all-binary" installations, not requiring anything to be
-compiled - fink, for example, can do this using the apt-get command or
-using the "<a href="finkcommander.sf.net">Fink Commander</a>" graphical
-package management tool.&nbsp; Even if what you are after is not
-available in a binary format, the package managers provide an
-"intermediate" solution, in that as long as you have the development
-environment installed, they can take care of the downloading and
-compiling of the sources and the installation of the resulting binaries
-automatically.<br>
-<br>
-The <a href="http://openosx.com/grass/">Open OS X port of GRASS</a> is
-a binary release with extra functionality, but its maintenance and
-documentation is a parallel, separate activity (which has contributed
-back some very useful fixes to the main GRASS project).&nbsp; As of
-this writing, it is still using version 5.0.2 of GRASS.<br>
-<br>
-Finally, it should be noted that <a
- href="http://fink.sourceforge.net/pdb/package.php/grass">GRASS itself
-is available as a package, in the Fink system</a>, although as of this
-writing it is also still at version 5.0.2. <br>
-<br>
-For most platforms, only the current "stable release" version of GRASS
-is made available in binary form.&nbsp; For the Mac platform, however,
-there have been a number of recent improvements in the development
-branches of the source code which specifically improve Mac
-compatibility and functionality.&nbsp; Therefore, individual volunteers
-have been working to provide binaries of GRASS 5.3 and 5.7 as
-well.&nbsp; See the <a href="roadmap.html">GRASS development roadmap</a>
-for explanations of the differences between these versions.<br>
-<span DEFANGED_STYLE="font-weight: bold;"></span>
-<p><b>Download pre-compiled Mac OS X
-binaries:</b>
-</p>
-<ul>
-  <li>Download precompiled
-package - by version</li>
-  <ul>
-    <li>GRASS 5.0.3:&nbsp; <br>
-    </li>
-    <li>GRASS 5.3-cvs:</li>
-    <li>GRASS 5.7-cvs:<br>
-    </li>
-  </ul>
-  <li><a
- href="grass5/binary/windows_cygnus/cygwin_grass50bininstall.html">Instructions
-to install the precompiled package.</a></li>
-</ul>
-<p><b><a href="GRASS.MacOSX.binnote.html">Other info to incorporate</a><br>
-</b></p>
-<p><b><br>
-Download source code
-(to compile GRASS from scratch on Windows):</b>
-</p>
-<ul>
-  <li>Get the latest <a href="download.html">GRASS
-5 sources.</a></li>
-  <li> <a
- href="macosx_grass50compile.html">Instructions
-on how to compile</a> GRASS 5.0 on Mac OS X.</li>
-</ul>
-<h3>FAQ (related to XXXX)</h3>
-<br>
-<br>
-<ul>
-</ul>
-<!-- FOOTER -->
-<hr>
-<div align="right">&copy; 2003 GRASS Development Team<br>
-<a href="mailto:weblist at grass.itc.it">Comments</a> about this page | <a
- href="faq/index.html">FAQ</a> | <a href="download.html">Download</a>
-| <a href="support.html">Support</a> | <a href="gdp/index.html">Docs</a>
-| <a href="grassdevel.html">Programming</a> | Back <a
- href="index.html">HOME</a><br>
-<i>Last change:
-$Date$
-</i></div>
-</body>
-</html>
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
  <DEFANGED_link href="../sitestyle.css" type="text/css" rel="stylesheet">
</head>
<body>
<center>
<h1>
5 on Mac OS X</h1>
<br>
</center>
<p>
</p>
</h1>
promptly.&nbsp; In
<br>
<br>
</h1>
 href="http://www.r-project.org">R statistics package</a>, this may be
<br>
is
<br>
<br>
<br>
<br>
<br>
<br>
 href="../grass5/source/REQUIREMENTS.html">GRASS
<br>
<br>
<br>
import tasks.<br>
<br>
<br>
<br>
<br>
using the "<a href="http://finkcommander.sf.net">Fink Commander</a>" graphical
automatically.<br>
<br>
<br>
<br>
well.&nbsp; See the <a href="../roadmap.html">GRASS development roadmap</a>
binaries:</b>
</p>
<ul>
  <ul>
      <ul>
        <li>official GRASS download site - still at version <a href="http://grass.ibiblio.org/grass5/binary/mac_os_x/">5.0.2</a></li>
        <li>testing version of 5.0.3: (missing) <br>
              </li>
      </ul>
    </li>
    <li>GRASS 5.3-cvs: <a href="http://wwwamb.bologna.enea.it/forgrass/">Lorenzo Moretti's binaries and instructions </a></li>
    <li>GRASS 5.7-cvs: <a href="http://wwwamb.bologna.enea.it/forgrass/">Lorenzo Moretti's binaries and instructions</a><br>
    </li>
  </ul>
</ul>
</b></p>
<p><b><br>
</p>
<ul>
  <li>Get the latest <a href="../download.html">GRASS
5 sources.</a></li>
  <li> <a
</ul>
<br>
<br>
<ul>
</ul>
<!-- FOOTER -->
<hr>
 href="../faq/index.html">FAQ</a> | <a href="../download.html">Download</a>
| <a href="../support.html">Support</a> | <a href="../gdp/index.html">Docs</a>
| <a href="../grassdevel.html">Programming</a> | Back <a
 href="../index.html">HOME</a><br>
<i>Last change:
$Date$
</i></div>
</body>
</html>
\ No newline at end of file
More information about the grass-web mailing list
