[GRASSweb-list]markus: web/grass51/binary/linux README.html,1.7,1.8
grass at intevation.de
Tue Feb 17 10:00:52 EST 2004
Author: markus
Update of /grassrepository/web/grass51/binary/linux
In directory doto:/tmp/cvs-serv22967
Modified Files:
README.html
Log Message:
Paolo Cavallini <cavallini at faunalia it>: updates
Index: README.html
RCS file: /grassrepository/web/grass51/binary/linux/README.html,v
retrieving revision 1.7
retrieving revision 1.8
diff -u -d -r1.7 -r1.8
--- README.html 11 Feb 2004 10:49:02 -0000 1.7
+++ README.html 17 Feb 2004 15:00:50 -0000 1.8
@@ -1,34 +1,77 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<HTML> <BODY BGCOLOR=#FFFFFF>
-<pre>
-This directory contains the Linux (x86/Intel) binary code for
-GRASS 5.7.x EXPERIMENTAL in gzipped tar format.
+<html>
+ <head>
+ <title>GRASS 5.7 Linux installation</title>
+ </head>
+ <body>
+<h1>How to install the Linux (x86/Intel) binary code for
+GRASS 5.7.x EXPERIMENTAL in gzipped tar format.</h1>
-<b>Note that this binary version may not work.
- Use at your own risk.</b>
+<h2>Note that this binary version may not work.<br>
+Use at your own risk.</h2>
You can install and use GRASS 5.7 in parallel to GRASS 5.0/5.3.
+<h3>Installation:</h3>
+<ol>
+ <li>get the file <br>grass57-DD-MM-YYYY-arch-bin.tar.gz</li>
+ <li>get the installation script <br> grass57-DD-MM-YYYY-arch-install.sh</li>
+</ol>
+<h4>where</h4>
+<ul>
+ <li>DD-MM-YYYY is the date of the release (e.g. 10_02_2004)</li>
+ <li>arc is the architecture of your platform (e.g. pc-linux-gnu)</li>
+</ul>
+<strong>Note</strong>: this code is highly experimental and may be malfunctioning.<br><br>
+For installation, run the install script with --help option:<br>
-Installation:
-1. get the file
- grass57-DD-MM-YYYY-arch-bin.tar.gz
+ <ul>
+ <li>sh grass57-DD-MM-YYYY-arch-install.sh --help </li>
+ or
+ <li>./grass57-DD-MM-YYYY-arch-install.sh --help </li>
+</ul><br>
-2. get the installation script
- grass57-DD-MM-YYYY-arch-install.sh
+Or without help, directly:<br>
+ <ul>
+ <li>sh grass57-DD-MM-YYYY-arch-install.sh grass57-DD-MM-YYYY-arc-bin.tar.gz</li>
+ or
+ <li>./grass57-DD-MM-YYYY-arch-install.sh grass57-DD-MM-YYYY-arc-bin.tar.gz</li>
+</ul>
+<h3>Libraries</h3>
+The following libraries are required:
+<ul>
+ <li>libpq (e.g. libpq3-7.3.4-2mdk.i586.rpm) </li>
+ <li>libproj (e.g. libproj0-4.4.7-1mdk.i586.rpm) </li>
+ <li>libgdal(e.g. libgdal0-1.1.9-2mdk.i586.rpm) </li>
+</ul>
-Note: this code is highly experimental and may be malfunctioning.<br>
-For installation, run the install script with --help option:
- grass57-DD-MM-YYYY-arch-install.sh --help
+and, recommended, also:
+ <ul>
+ <li>tcl (e.g. tcl-8.3.3-21mdk.i586.rpm)</li>
+ <li>tk (e.g. tk-8.3.3-21mdk.i586.rpm)</li>
+ <li>gdal tools (e.g. gdal-1.1.9-2mdk.i586.rpm)</li>
+ <li>libfftw (must be fft2, e.g. libfftw2-2.1.5-2mdk.i586.rpm)</li>
+</ul>
+<h3>NOTE:</h3>
+In some distributions (e.g. Mandrake) the names of libraries is slightly different. Check, and if there is no file of the name:<br>
+libtk.so.0<br>
+libtcl.so.0<br>
+libpq.so.2<br><br>
+then you should type:<br><br>
+ su<br>
+ ln -s /usr/lib/libtk.so /usr/lib/libtk.so.0<br>
+ ln -s /usr/lib/libtcl.so /usr/lib/libtcl.so.0<br>
+ ln -s /usr/lib/libpq.so.3 /usr/lib/libpq.so.2<br>
+ ldconfig
+<p>
+Instead of (or in addition to) libtk.so and libtcl.so, you might have
+libtk8.4.so and libtcl8.4.so. In this case, type instead:<br><br>
+ ln -s /usr/lib/libtk8.4.so /usr/lib/libtk.so.0<br>
+ ln -s /usr/lib/libtcl8.4.so /usr/lib/libtcl.so.0<br>
+ ldconfig<br>
<hr>
-Please help us and report bugs.
+Please help us and report bugs.<br>
<a href=http://grass.itc.it/bugtracking/bugreport.html>Bug report form</a>
-</pre>
-Get this <a href=README.html>file.</a>
-</HTML>
+</body>
+</html>
More information about the grass-web
