[GRASSweb-list]markus: web/grass5 index.html,1.29,1.30
grass at intevation.de
Thu Feb 19 11:18:18 EST 2004
Author: markus
Update of /grassrepository/web/grass5
In directory doto:/tmp/cvs-serv23478
Modified Files:
Log Message:
fixes
Index: index.html
RCS file: /grassrepository/web/grass5/index.html,v
retrieving revision 1.29
retrieving revision 1.30
diff -u -d -r1.29 -r1.30
--- index.html 11 Nov 2003 19:38:26 -0000 1.29
+++ index.html 19 Feb 2004 16:18:16 -0000 1.30
@@ -40,14 +40,15 @@
<b>5.3</b> is the development version of 5.0. It will include anything which
is added to the 5.0 branch (although such changes will typically go
into 5.3 initially, then get merged into the 5.0 branch later), plus
-some other changes which are too intrusive to go into the 5.3.x
+some other changes which are too intrusive to go into the 5.0.x
releases (e.g. because they break backwards compatibility, or
introduce additional dependencies).
<br>
<b>5.7</b> is the experimental version which was previously referred to as
"5.1". See <a href=../grass51/index.html>related web pages</a>.
<P>
+For features details, please refer to the <a href="../roadmap.html">Roadmap</a>.
+<P>
<b>Current stable version:</b>
GRASS 5.0.3 (released 6 November 2003), GRASS 5.0.3 is a bugfix release only.
<p>
@@ -95,22 +96,20 @@
<h2>GRASS 5.0 documents</h2>
<ul>
-<li>GRASS 5.0 manual pages:
-<a href="../gdp/html_grass5/index.html">HTML</a> -
-<a href="manuals/">PDF</a>
+<li>GRASS 5 <a href="../gdp/online.html">User manuals</a>
<li><a href="../grassdevel.html#prog">Programmer's manual</a>
</ul>
<a name="bugs"></A>
<h2>Bug reports</h2>
-<menu>
+<ul>
<li> You are kindly requested to send your comments about GRASS 5 functionality
(recent version).
<li>List of <a href="http://intevation.de/rt/webrt?q_queue=grass">known bugs
in this GRASS 5.0.x version</A>. Your help to fix these bugs is highly appreciated. If you find
a bug, please check the list if it is already known. If not, you are kindly
requested to report the bug(s) to use our new <a href="../bugtracking/bugreport.html">bug report form</a>
-</menu>
+</ul>
<a name="cluster"></a>
<h2>Clustered GRASS GIS</h2>
@@ -174,7 +173,7 @@
<!-- FOOTER -->
<hr>
-<DIV ALIGN=right>© 1999-2003 GRASS Development Team<br>
+<DIV ALIGN=right>© 1999-2004 GRASS Development Team<br>
<a href="mailto:weblist at grass.itc.it">Comments</a> about this page | <a href="../faq/index.html">FAQ</a> | <a href="../download.html">Download</a> | <a href="../support.html">Support</a> | <a href="../gdp/index.html">Docs</a> | <a href="../grassdevel.html">Programming</a> | Back <a href=../index.html>HOME</a><br>
<i>Last change:
$Date$
More information about the grass-web
