[GRASSweb-list]Bogofilter installed to catch spams
Markus Neteler
neteler at itc.it
Fri Jan 9 10:00:10 EST 2004
YES:
procmail: Executing "/usr/local/bin/bogofilter,-u,-e,-p"
Can't open file 'wordlist.db' in directory '/var/lib/bogofilter'.
error #13 - Permission denied.
Remember to register some spam and ham messages before you
use bogofilter to evaluate mail for its probable spam status!
procmail: Non-zero exitcode (3) from "/usr/local/bin/bogofilter"
procmail: No match on "/usr/local/bin/bogofilter -u -e -p"
Thanks, Sergiuz, for letting me check the permissions of
the procmail.log file which finally made visible the problem.
Hope this mail contains the spamicity header.
Markus
On Fri, Jan 09, 2004 at 03:57:33PM +0100, Markus Neteler wrote:
> For a test you will have to accept this useless mail.
> (takes me too much time to set up a new test ML, there is none)
> BTW: Sanitizer is also running which catches most of
> poisoned attachments.
> M.
> weblist mailing list
> weblist at grass.itc.it
> http://grass.itc.it/mailman/listinfo/weblist
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
More information about the grass-web
