[GRASSweb-list]markus: web roadmap.html,1.11,1.12
grass at intevation.de
Thu Jan 29 08:22:59 EST 2004
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv15204
Modified Files:
roadmap.html
Log Message:
some updates
Index: roadmap.html
RCS file: /grassrepository/web/roadmap.html,v
retrieving revision 1.11
retrieving revision 1.12
diff -u -d -r1.11 -r1.12
--- roadmap.html 21 Oct 2003 09:15:43 -0000 1.11
+++ roadmap.html 29 Jan 2004 13:22:56 -0000 1.12
@@ -31,7 +31,7 @@
Version numbers scheme:
<ul>
<li>first number: major release number
- <li>secondary number: stable/unstable indicator
+ <li>secondary number: stable/development indicator
<li>third number: subversions of releases
</ul>
<P>
@@ -46,7 +46,7 @@
(even secondary number)</span></big></big><br>
</td>
<td style="vertical-align: top;"><big style="font-weight:
-bold;"><big>unstable<br>
+bold;"><big>development<br>
(odd secondary number)</big></big><br>
</td>
</tr>
@@ -56,7 +56,7 @@
rowspan="3" colspan="1"><big><big>GRASS 5.x</big></big><br>
</td>
<td
- style="vertical-align: top; background-color: rgb(153, 255, 153);"><a href="grass5/index.html">5.0.2 (current)</a>
+ style="vertical-align: top; background-color: rgb(153, 255, 153);"><a href="grass5/index.html">5.0.3 (current)</a>
</td>
<td
style="vertical-align: top; background-color: rgb(153, 255, 153);"><i>[5.1-cvs: renamed to 5.7-cvs]</i>
@@ -64,9 +64,9 @@
</tr>
<tr>
<td
- style="vertical-align: top; background-color: rgb(153, 255, 153);">5.0.3
+ style="vertical-align: top; background-color: rgb(153, 255, 153);">(5.0.4)
<ul>
- <li>bugfixes for 5.0.2</li>
+ <li>bugfixes for 5.0.3, if needed</li>
</ul>
</td>
<td
@@ -76,6 +76,8 @@
<li>improved NVIZ</li>
<li>G3D activated</li>
<li>r.terraflow (C++)</li>
+ <li>improved source code portability
+ <li>probably better tested than 5.0.3
</ul>
</td>
</tr>
@@ -107,9 +109,10 @@
<li>new 2D/3D vector engine (almost done)</li>
<li>new vector network library (done, needs fixes)</li>
<li>DBMS support (partially done, PG driver needs rewrite)</li>
+ <li>migration of old vector modules (almost done)</li>
<li>keep sites format [1] ("done")</li>
<li>new Makefile system (TODO)</li>
- <li>shared libraries (done)</li>
+ <li>shared libraries (done), static libraries also supported</li>
<li>initial cleanup libs (TODO)</li>
<li>initial code inline docs (doxygen based, TODO)</li>
</ul>
More information about the grass-web
