[GRASSweb-list]hamish: web/nviz index.html,1.5,1.6
grass at intevation.de grass at intevation.de
Thu Jul 15 03:27:58 EDT 2004
Author: hamish
Update of /grassrepository/web/nviz
In directory doto:/tmp/cvs-serv29913/web/nviz
Modified Files:
Log Message:
add note about mpeg encoding software
Index: index.html
RCS file: /grassrepository/web/nviz/index.html,v
retrieving revision 1.5
retrieving revision 1.6
diff -u -d -r1.5 -r1.6
--- index.html	7 Mar 2003 08:21:38 -0000	1.5
+++ index.html	15 Jul 2004 07:27:55 -0000	1.6
@@ -48,7 +48,7 @@
 You can generate MPEG animations
 with <a href="../nviz/index.html">NVIZ</a>.
 You need the <a href="ftp://mm-ftp.cs.berkeley.edu/pub/multimedia/mpeg/encode/">mpeg_encoder</a>
-installed.</li>
+installed (often already present as 'ppmtompeg' from NetPBM, just symlink).</li>
 <br>Here is a file to control
 the mpeg_encode software: <a href="../faq/mpegparam.txt">mpegparam.txt</a>.
More information about the grass-web mailing list
