[GRASSweb-list]markus: web/grass57 index.html,1.70,1.71
grass at intevation.de grass at intevation.de
Wed Jul 21 09:14:15 EDT 2004
Author: markus
Update of /grassrepository/web/grass57
In directory doto:/tmp/cvs-serv23586
Modified Files:
Log Message:
multiple GRASS sessions added
Index: index.html
RCS file: /grassrepository/web/grass57/index.html,v
retrieving revision 1.70
retrieving revision 1.71
diff -u -d -r1.70 -r1.71
--- index.html	15 Jul 2004 14:05:12 -0000	1.70
+++ index.html	21 Jul 2004 13:14:12 -0000	1.71
@@ -92,7 +92,7 @@
 <ul>
  <li><b>SQL queries/selects</b> supported by vector modules</li>
- <li><b>attributes updating</b>is  supported through the forms library
+ <li><b>attributes updating</b> is  supported through the forms library
   (d.what.vect lets you modify directly the attached attributes)</li>
  <li>
@@ -104,14 +104,16 @@
  <li>new <b>v.digit with GUI</b> under construction (<a
    href=http://mpa.itc.it/radim/g51/v.digit3.png>screenshot</a>)</li>
- <li><b>export of any <a href=http://www.remotesensing.org/gdal/ogr/>OGR
+ <li><b>import and export of any <a href=http://www.remotesensing.org/gdal/ogr/>OGR
   vector formats</a></b> as supported by OGR (Shapefile, TIGER,
   MapInfo and GML2, PostGIS and DGN)</li>
  <li> <b>GUI generated by front end on runtime</b> and <b>display
  manager</b> (<a href=http://mpa.itc.it/radim/g51/>screenshots</a>)</li>
- <li> i18n: support for multiple languages (at time framework implemented,
+ <li> i18n: support for <b>multiple languages<b> (at time framework implemented,
     translators needed)</li>
+ <li> <b>multiple GRASS sessions</b>: a user can start more than one session
+  in parallel</li>
 </ul>
 </ul>
More information about the grass-web mailing list
