[GRASSweb-list]hamish: web/announces announce_grass570.html,1.4,1.5
grass at intevation.de
Wed Jun 23 23:07:39 EDT 2004
- Previous message: [GRASSweb-list]markus: web/announces announce_grass570.html,1.3,1.4
- Next message: [GRASSweb-list]markus: web/images grass570_displaymanager_gardalake_srtm.jpg,NONE,1.1 grass570_displaymanager_gardalake_srtm_small.jpg,NONE,1.1 grass570_vdigit_spearfish.jpg,NONE,1.1 grass570_vdigit_spearfish_small.jpg,NONE,1.1
- Messages sorted by:
[ date ]
[ thread ]
[ subject ]
[ author ]
Author: hamish
Update of /grassrepository/web/announces
In directory doto:/tmp/cvs-serv9879
Modified Files:
Log Message:
lots of editorial changes, add some links
Index: announce_grass570.html
RCS file: /grassrepository/web/announces/announce_grass570.html,v
retrieving revision 1.4
retrieving revision 1.5
diff -u -d -r1.4 -r1.5
--- announce_grass570.html 22 Jun 2004 12:09:26 -0000 1.4
+++ announce_grass570.html 24 Jun 2004 03:07:36 -0000 1.5
@@ -12,9 +12,13 @@
<h2>GRASS GIS 5.7.0 released 17 June 2004</h2>
-<p>After more than two years of development a revamped GRASS implementation
-has been published. This is a first official release (see the
-<a href="../roadmap.html">GRASS Development Roadmap</a>).</p>
+<p>
+After more than two years of development the first official release of
+the next generation implementation of <a href="http://grass.itc.it">GRASS</a>
+has been published<!-- .
+<P>
+This is a "technology preview" release -->
+(see the <a href="../roadmap.html">GRASS Development Roadmap</a>).</p>
<p>The Geographic Resources Analysis Support System, commonly referred to as
GRASS GIS, is a Geographical Information System (GIS) used for data
@@ -47,55 +51,60 @@
<p><b>Geometry management:</b>
-GRASS 5.7.0 comes with a completely overhauled vector engine which was
-extended to manage 2D and 3D topological vector data. A new spatial
-indexing system accelerates data access.
-Vector data can be imported (which allows for topological data cleanup)
-as well as live-linked into the GRASS database. A new library, the
-Directed Graph Library, provides support for vector network analysis.
+GRASS 5.7.0 comes with a completely overhauled vector engine which is
+extended to manage 2D and 3D topological vector data. In addition, a new
+spatial indexing system accelerates data access. Vector data from other
+GIS software can be imported (allowing for topological data clean-up) as
+well as live-linked into the GRASS database. The new Directed Graph
+Library provides support for vector network analysis.
<P><b>Attribute management:</b>
-Full and flexible integration of database management systems (DBMS)
-for attribute management is part of the new vector engine
-(at time PostgreSQL, mySQL, DBF, ODBC supported). SQL statements are
-used to manage attributes. Graphical updating of vector attributes
-has been implemented.
+The new vector engine includes full and flexible integration of database
+management systems (DBMS) for attribute management
+(currently PostgreSQL, mySQL, DBF, and ODBC are supported). SQL statements
+are used to manage attributes. Graphical updating of vector attributes
+has been implemented as well.
<P><b>User interface:</b>
-A graphical user interface for every module is generated on the fly.
-A new display manager has been implemented, but the classical 'tcltkgrass'
-Graphical User Interface menu structure (updated) is also available.
-NVIZ was enhanced to display 3D vector data.
-And a completely new graphical digitizing tool has been implemented.
+A graphical user interface (GUI) for every module is now generated on the fly.
+A new display manager has been implemented, which is supplemented by an updated
+version of the classic 'tcltkgrass' GUI menu structure.
+NVIZ, the included visualization package, is enhanced to display 3D vector data.
+Additionally, a completely new graphical tool for digitizing has been implemented.
-<P><b>Multi session:</b>
-Users can run concurrent GRASS 5.7 sessions now. It is also possible
+<P><b>Multi-session:</b>
+Users can now run concurrent GRASS 5.7 sessions. It is also possible
to run GRASS 5.3.x and 5.7.0 in parallel in the same LOCATION.
-<P><b>Generating GRASS LOCATIONs:</b>
-LOCATIONs can be generated by EPSG code number from the startup screen.
-Within a GRASS session LOCATIONs can be created from existing datasets
-(raster data as well as vector data).
+<P><b>Generating new GRASS LOCATIONs:</b>
+New LOCATIONs with automatically set projection information can be generated
+by <a href="http://www.epsg.org">EPSG code number</a> from the start-up screen.
+Within a GRASS session, LOCATIONs can be automatically created from existing
+datasets (raster data as well as vector data).
<P><b>Data Import/Export:</b>
-GRASS 5.7.0 is integrated with the GDAL/OGR library to support
-a wide range of raster and vector formats. OGC-conformal Simple Features
-vector data are converted to the topological GRASS format; vice verse
-the export into Simple Features is possible.
+GRASS 5.7.0 is integrated with the
+<a href="http://www.remotesensing.org/gdal">GDAL</a>/<a href="http://www.remotesensing.org/ogr">OGR</a>
+library to support an extensive range of raster and vector formats.
+<a href="http://www.opengis.org">OGC</a>-conformal Simple Features vector
+data are converted into the topological GRASS format; conversely, export
+into Simple Features is also possible.
<P><b>Enhancements included from 5.3.0:</b>
-This release bundles the new vector capabilities with all improvements
-of <a href="announce_grass530.html">GRASS 5.3.0</a> (support of
-datum transformation, use of external PROJ4 and GDAL/OGR libraries,
-shared libraries making binaries significantly smaller, G3D 3-D Raster
-Voxel tools). The raster capabilities are identical with 5.3.0.
+This release bundles the new vector capabilities with all the improvements
+from <a href="announce_grass530.html">GRASS 5.3.0</a> (e.g. support for
+datum transformation, use of external
+<a href="http://www.remotesensing.org/proj">PROJ4</a> and GDAL/OGR libraries,
+shared libraries making binary distributions significantly smaller, G3D 3-D Raster
+Voxel tools). The raster capabilities of 5.7.0 are identical with those of 5.3.0.
<P>
For a more comprehensive list of changed modules see the
<a href="../grass57/source/ChangeLog">ChangeLog</a>.</p>
-<p>We are always looking for both testers and developers to help us maintain
-and accelerate this development cycle.</p>
+<p><BR><i>We are always looking for both testers and developers to
+<a href="../grassdevel.html">help</a> us maintain and accelerate this
+development cycle.</i></p>
<hr>
<address>
[ date ]
[ thread ]
[ subject ]
[ author ]
More information about the grass-web
