[GRASSweb-list]markus: web/grass51/binary/linux README.html,1.8,1.9
grass at intevation.de
Mon Mar 15 11:30:44 EST 2004
Author: markus
Update of /grassrepository/web/grass51/binary/linux
In directory doto:/tmp/cvs-serv19482
Modified Files:
README.html
Log Message:
updated
Index: README.html
RCS file: /grassrepository/web/grass51/binary/linux/README.html,v
retrieving revision 1.8
retrieving revision 1.9
diff -u -d -r1.8 -r1.9
--- README.html 17 Feb 2004 15:00:50 -0000 1.8
+++ README.html 15 Mar 2004 16:30:42 -0000 1.9
@@ -1,77 +1,94 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2 Final//EN">
<html>
- <head>
- <title>GRASS 5.7 Linux installation</title>
- </head>
- <body>
+<head>
+ <title>Index of /grass51/binary/linux</title>
+</head>
+<body>
<h1>How to install the Linux (x86/Intel) binary code for
-GRASS 5.7.x EXPERIMENTAL in gzipped tar format.</h1>
+ GRASS 5.7.x EXPERIMENTAL in gzipped tar format.</h1>
<h2>Note that this binary version may not work.<br>
-Use at your own risk.</h2>
+ Use at your own risk.</h2>
You can install and use GRASS 5.7 in parallel to GRASS 5.0/5.3.
<h3>Installation:</h3>
<ol>
- <li>get the file <br>grass57-DD-MM-YYYY-arch-bin.tar.gz</li>
- <li>get the installation script <br> grass57-DD-MM-YYYY-arch-install.sh</li>
+ <li>get the file <br>
+grass57-DD-MM-YYYY-arch-bin.tar.gz</li>
+ <li>get the installation script <br>
+grass57-DD-MM-YYYY-arch-install.sh</li>
</ol>
<h4>where</h4>
<ul>
<li>DD-MM-YYYY is the date of the release (e.g. 10_02_2004)</li>
<li>arc is the architecture of your platform (e.g. pc-linux-gnu)</li>
</ul>
-<strong>Note</strong>: this code is highly experimental and may be malfunctioning.<br><br>
+<strong>Note</strong>: this code is highly experimental and may be
+malfunctioning.<br>
+<br>
For installation, run the install script with --help option:<br>
- <ul>
- <li>sh grass57-DD-MM-YYYY-arch-install.sh --help </li>
- or
- <li>./grass57-DD-MM-YYYY-arch-install.sh --help </li>
-</ul><br>
+<ul>
+ <li>sh grass57-DD-MM-YYYY-arch-install.sh --help </li>
+or <li>./grass57-DD-MM-YYYY-arch-install.sh --help </li>
+</ul>
+<br>
Or without help, directly:<br>
- <ul>
- <li>sh grass57-DD-MM-YYYY-arch-install.sh grass57-DD-MM-YYYY-arc-bin.tar.gz</li>
- or
- <li>./grass57-DD-MM-YYYY-arch-install.sh grass57-DD-MM-YYYY-arc-bin.tar.gz</li>
+<ul>
+grass57-DD-MM-YYYY-arc-bin.tar.gz</li>
</ul>
<h3>Libraries</h3>
The following libraries are required:
<ul>
- <li>libpq (e.g. libpq3-7.3.4-2mdk.i586.rpm) </li>
- <li>libproj (e.g. libproj0-4.4.7-1mdk.i586.rpm) </li>
- <li>libgdal(e.g. libgdal0-1.1.9-2mdk.i586.rpm) </li>
+ <li>libpq (e.g. libpq3-7.3.4-2mdk.i586.rpm)</li>
+ <li>proj (e.g. proj-4.4.7-1mdk.i586.rpm)</li>
+ <li>libproj (e.g. libproj0-4.4.7-1mdk.i586.rpm) </li>
+ <li>libgdal(e.g. libgdal0-1.1.9-2mdk.i586.rpm) </li>
</ul>
and, recommended, also:
- <ul>
+<ul>
<li>tcl (e.g. tcl-8.3.3-21mdk.i586.rpm)</li>
<li>tk (e.g. tk-8.3.3-21mdk.i586.rpm)</li>
<li>gdal tools (e.g. gdal-1.1.9-2mdk.i586.rpm)</li>
<li>libfftw (must be fft2, e.g. libfftw2-2.1.5-2mdk.i586.rpm)</li>
+ <li>libgrass (e.g. libgrass5-1.0.0-1mdk.src.rpm - but only if inserted in one of above packages as dependency)<br>
+ </li>
</ul>
+optional:<br>
+<ul>
+ <li>libgdal0-devel-1.1.9-2mdk.i586.rpm</li>
+ <li>libgrass5_0-devel-1.0.0-1mdk.i586.rpm</li>
+ <li>libproj0-devel-4.4.7-1mdk.i586.rpm</li>
+</ul>
+You can find these RPMs on <a href="http://www.rpmfind.net/">www.rpmfind.net</a>
<h3>NOTE:</h3>
-In some distributions (e.g. Mandrake) the names of libraries is slightly different. Check, and if there is no file of the name:<br>
+In some distributions (e.g. Mandrake) the names of libraries is
+slightly different. Check, and if there is no file of the name:<br>
libtk.so.0<br>
libtcl.so.0<br>
-libpq.so.2<br><br>
-then you should type:<br><br>
- su<br>
- ln -s /usr/lib/libtk.so /usr/lib/libtk.so.0<br>
- ln -s /usr/lib/libtcl.so /usr/lib/libtcl.so.0<br>
- ln -s /usr/lib/libpq.so.3 /usr/lib/libpq.so.2<br>
- ldconfig
-<p>
-Instead of (or in addition to) libtk.so and libtcl.so, you might have
-libtk8.4.so and libtcl8.4.so. In this case, type instead:<br><br>
- ln -s /usr/lib/libtk8.4.so /usr/lib/libtk.so.0<br>
- ln -s /usr/lib/libtcl8.4.so /usr/lib/libtcl.so.0<br>
- ldconfig<br>
-<hr>
-Please help us and report bugs.<br>
-<a href=http://grass.itc.it/bugtracking/bugreport.html>Bug report form</a>
+libpq.so.2<br>
+libgdal.1.1.so<br>
+<br>
+then you should type:<br>
+<br>
+su<br>
+ln -s /usr/lib/libtk.so /usr/lib/libtk.so.0<br>
+ln -s /usr/lib/libtcl.so /usr/lib/libtcl.so.0<br>
+ln -s /usr/lib/libpq.so.3 /usr/lib/libpq.so.2<br>
+ln -s /usr/lib/libgdal.1.1.so /usr/lib/libgdal.so.1<br>
+ldconfig
+<p>Instead of (or in addition to) libtk.so and libtcl.so, you might
+ have libtk8.4.so and libtcl8.4.so. In this case, type instead:<br>
+<br>
+ln -s /usr/lib/libtk8.4.so /usr/lib/libtk.so.0<br>
+ln -s /usr/lib/libtcl8.4.so /usr/lib/libtcl.so.0<br>
+ldconfig<br>
+</p>
+<hr>Please help us and report bugs.<br>
+<a href="http://grass.itc.it/bugtracking/bugreport.html">Bug report form</a>
</body>
</html>
More information about the grass-web
