[GRASSweb-list]bob: web/gdp/nviz nviz_panel_dsf1.html,NONE,1.1 nviz_panel_dsf2.html,NONE,1.1 nviz_panel_dsf3.html,NONE,1.1 nviz_panel_kanim.html,NONE,1.1 nviz_panel_labels.html,NONE,1.1 nviz_panel_pos.html,NONE,1.1 nviz_panel_scale.html,NONE,1.1 nviz_panel
grass at intevation.de grass at intevation.de
Fri Mar 26 11:05:51 EST 2004
Author: bob
Update of /grassrepository/web/gdp/nviz
In directory doto:/tmp/cvs-serv31470
Modified Files:
	nviz_panel_dsf.html nviz_panel_lights.html
	nviz_panel_move.html
Added Files:
	nviz_panel_dsf1.html nviz_panel_dsf2.html nviz_panel_dsf3.html
	nviz_panel_kanim.html nviz_panel_labels.html
	nviz_panel_pos.html nviz_panel_scale.html
Log Message:
New NVIZ Documentation
--- NEW FILE: nviz_panel_dsf1.html ---
<html>
<head>
   <DEFANGED_meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
   <DEFANGED_meta name="GENERATOR" content="Mozilla/4.76 [de] (X11; U; Linux 2.2.16 i686) [Netscape]">
   <title>GRASS 5.0 Tutorial for nviz</title>
</head>
<body bgcolor="#FFFFFF" link="#0000DF" vlink="#006000">
<h1><DEFANGED_IMG src="grass.smlogo.gif">NVIZ Reference Manual</h1>
<hr width="100%" align=center size=4 noshade>
<p>
<a href="nviz_toc.html">CONTENTS</a>
<br>
<a href="nviz_panel_dsf.html">BACK</a>
</p>
<h2>Mkdspf Panel - Individual Thresholds</h2>
<p>
On the <strong>Mkdspf Panel</strong>, you use the <strong>Individual</strong> thresholds option to add individual or custom isosurface thresholds.
</p>
<DEFANGED_IMG src="nvimg/panel/mkdspf.gif" alt="Mkdspf Individual Menu" width="291" height="359">
<h3>OPTIONS</h3>
<dl>
<dt> <strong>Iso Levels</strong></dt>
<dd>Enter the elevation of an individual isosurface. Click <strong>Add</strong> or press <strong>Enter</strong> to add the value to the <strong>Individual Thresholds</strong> list. <br><br></dd>
<dt> <strong>Add</strong></dt>
<dd>Adds the value set in <strong>Iso Levels</strong> to the <strong>Individual Thresholds</strong> list.
<br><br></dd>
<dt> <strong>Delete</strong></dt>
<dd>Removes a selected value from the <strong>Individual Thresholds</strong> list.
<br><br></dd>
</dl>
</body>
</html>
--- NEW FILE: nviz_panel_dsf2.html ---
<html>
<head>
</head>
<p>
<br>
</p>
<h2>Mkdspf Panel - Complete Threshold</h2>
<p>
On the <strong>Mkdspf Panel</strong>, you use the <strong>Complete</strong> threshold option to create an evenly spaced set of display isosurfaces covering the complete range of the <strong>Input File</strong>.
</p>
<DEFANGED_IMG src="nvimg/panel/mkdspf_complete.gif" alt="Mkdspf Complete Menu" width="291" height="214">
<h3>OPTIONS</h3>
<dl>
<dt> <strong>Interval Size</strong></dt>
<dd>Sets the interval between the display isosurfaces.
<br><br></dd>
</dl>
</body>
</html>
--- NEW FILE: nviz_panel_dsf3.html ---
<html>
<head>
</head>
<p>
<br>
</p>
<h2>Mkdspf Panel - Range Threshold</h2>
<p>
On the <strong>Mkdspf Panel</strong>, you use the <strong>Range</strong> threshold option to create an evenly spaced set of display isosurfaces covering a user defined range of the <strong>Input File</strong>.
</p>
<DEFANGED_IMG src="nvimg/panel/mkdspf_range.gif" alt="Mkdspf Range Menu" width="294" height="268" >
<h3>OPTIONS</h3>
<dl>
<dt> <strong>Min</strong></dt>
<dd>Enter the minimum or start value for the display isosurfaces.
<br><br></dd>
<dt> <strong>Max</strong></dt>
<dd>Enter the maximum or stop value for the display isosurfaces.
<br><br></dd>
<dt> <strong>Levels</strong></dt>
<dd>Enter the number of isosurfaces to create between the minimum and maximum.
<br><br></dd>
<dt> <strong>Interpolation Type</strong></dt>
<dd>
	<dl>
	<dt><strong>Linear</strong></dt>
	<dd>Uses a linear interpolation to calculate the display isosurfaces levels.
	<br><br></dd>
	<dt><strong>Logarithmic</strong></dt>
	<dd>Uses a logarithmic interpolation to calculate the display isosurfaces levels.
	<br><br></dd>
	<dt><strong>Quadratic</strong></dt>
	<dd>Uses a quadratic interpolation to calculate the display isosurfaces levels.
	<br><br></dd>
	<dt><strong>Arbitrary</strong></dt>
	<dd>Uses an arbitrary interpolation based on the entered arbitrary value to calculate the display isosurfaces levels.
	<br><br></dd></dl>
</dd>
</dl>
</body>
</html>
--- NEW FILE: nviz_panel_kanim.html ---
<html>
<head>
 </head>
<p>
</p>
<h2>Keyframe Animation Panel</h2>
<p>The <strong>Keyframe Animation</strong> panel lets you create complex animations where you need precise camera control. Each keyframe that you set has nine <em>channels</em>, and each <em>channel</em> represents a part of the current view. For example, the <em>Field of View</em> (FOV) is a separate channel in each keyframe.
</p>
<DEFANGED_IMG src="nvimg/panel/keyanim.gif" alt="Keyframe Animation Panel" width="355" height="436">
<h3>OPTIONS</h3>
<dl>
<dt><DEFANGED_IMG src="nvimg/panel/anim2.gif" alt="Play Reverse" width="16" height="16"> (Reverse Play)</dt>
<dd>Plays the animation backwards.
<br><br></dd>
<dt><DEFANGED_IMG src="nvimg/panel/anim1.gif" alt="Step Back" width="16" height="16"> (Reverse)</dt>
<dd>Moves backward through the animation one frame at a time.
<br><br></dd>
<dt><DEFANGED_IMG src="nvimg/panel/anim5.gif" alt="Stop" width="16" height="16"> (Stop)</dt>
<dd>Stops the animation.
<br><br></dd>
<dt><DEFANGED_IMG src="nvimg/panel/anim3.gif" alt="Step Forward" width="16" height="16">(Forward)</dt>
<dd>Moves forward through the animation one frame at a time.
<br><br></dd>
<dt><DEFANGED_IMG src="nvimg/panel/anim4.gif" alt="Play" width="16" height="16">(Play)</dt>
<dd>Plays the animation.
<br><br></dd>
<dt> <strong>Framerate</strong></dt>
<dd>Sets the framerate (frames per second) for the animation.
<br><br></dd>
<dt> <strong>Keyframe Attributes</strong></dt>
<dd>The <strong>Keyframe Attributes</strong> scrollbar on the left moves through the nine channels of each keyframe. The bottom scrollbar moves through the user defined keyframes.
A thick vertical blue line marks the current position (frame) in the animation. The key time appears below this line in black. A light blue rectangle indicates selected channels for each keyframe. The key time for each keyframe appears below in light blue.
<br>
To change the current position (frame) in the animation, click or click and drag in the channels area. To change the position (time) of the selected keyframe, click and drag the key time. To select a keyframe(s) for deletion, middle-click the key time.
<br><br>
<DEFANGED_IMG src="nvimg/panel/keyexample.gif" alt="Keyframe Attributes" width="354" height="226">
<br><br>
<dl>
<dt> <strong>Channels</strong></dt>
<dd>Each keyframe has nine channels that you can either turn on or off. The default for all channels is on. You need to set your channel options before adding a keyframe.
<br><br></dd>
<dd>
	<dl>
	<dt> <strong>FromX</strong></dt>
	<dd>Records the X coordinate of the camera (if selected).
	<br><br></dd>
	<dt> <strong>FromY</strong></dt>
	<dd>Records the Y coordinate of the camera (if selected).
	<br><br></dd>
	<dt> <strong>FromZ</strong></dt>
	<dd>Records the Z coordinate of the camera (if selected).
	<br><br></dd>
	<dt> <strong>DirX</strong></dt>
	<dd>Records the X coordinate of the center of view (if selected).
	<br><br></dd>
	<dt> <strong>DirY</strong></dt>
	<dd>Records the Y coordinate of the center of view (if selected).
	<br><br></dd>
	<dt> <strong>DirZ</strong></dt>
	<dd>Records the Z coordinate of the center of view (if selected).
	<br><br></dd>
	<dt> <strong>FOV</strong></dt>
	<dd>Records the Field of View (if selected).
	<br><br></dd>
	<dt> <strong>TWIST</strong></dt>
	<dd>Records the twist of the camera (if selected).
	<br><br></dd>
	<dt> <strong>cplane-0</strong></dt>
	<dd>Records the current position of the cutting plane (if selected).
	<br><br></dd>
	</dl>
</dd>
</dl></dd>
<dd>Adds a key frame at the current key time. The <strong>New Key Time</strong> automatically increments by 1 minute after each keyframe is added.
<br><br></dd>
<dd>Deletes all selected keyframes from the animation. You select keyframes from the <strong>Keyframe Attributes</strong> by middle-clicking on the key time. Deleted keyframes are not recoverable.
<br><br></dd>
<dt> <strong>New Key Time</strong></dt>
<dd>Allows you to set a new key time. You enter key times as minutes, seconds, and frame number. Each time you add a keyframe, the key time automatically increments by 1 minute.
To calculate the length of the animation (in frames), use this formula <em>(minutes*60 + seconds)*frame rate + frame number</em>.
<br><br></dd>
<dt> <strong>Show</strong></dt>
<dd>Use the next three options to annotate the animation.
<br><br></dd>
<dd>
	<dl>
	<dt> <strong>Path</strong></dt>
	<dd>Shows the path that the animation follows between key frames (if selected). This is useful for adjusting the tension if using a spline interpolation.
	<br><br></dd>
	<dt> <strong>Vect</strong></dt>
	<dd>Draws all loaded vector files in the animation (if selected).
	<br><br></dd>
	<dt> <strong>Sites</strong></dt>
	<dd>Draws all loaded sites files in the animation (if selected).
	<br><br></dd>
	</dl>
</dd>
<dt> <strong>Interp.</strong></dt>
<dd>Sets the interpolation used between key frames.
<br><br></dd>
<dd>
	<dl>
	<dt> <strong>Linear</strong></dt>
	<dd>Uses a linear interpolation between key frames.
	<br><br></dd>
	<dt> <strong>Spline</strong></dt>
	<dd>Uses a spline interpolation between key frames at the selected tension.
	<br><br></dd>
	<dt> <strong>Tension</strong></dt>
	<dd>Sets the tension of the spline interpolation.
	<br><br></dd>
	</dl>
</dd>
<dt> <strong>File</strong></dt>
<dd>
	<dl>
	<dt> <strong>Save</strong></dt>
	<dd>Saves the keyframes attributes to a user defined file.
	<br><br></dd>
	<dt> <strong>Load</strong></dt>
	<dd>Loads a previously saved keyframe animation file.
	<br><br></dd>
	</dl>
</dd>
<dt> <strong>Run and Save</strong></dt>
<dd>Runs the animation and saves each frame as an image. You must supply a file name prefix, frame start number, image type, and draw type. The image file name includes the file prefix, frame number and image type. For example, frame number 12 with a file prefix of FLY saved as a PPM would be named FLY0012.ppm. You can choose to render the animation off-screen (in memory). To render off-screen, you need to minimize the <strong>NVIZ</strong> viewer.
<br><br></dd>
<dt><strong>Close</strong></dt>
<dd>Closes the <strong>KeyFrame Animation</strong> panel.<br><br></dd>
</body>
</html>
--- NEW FILE: nviz_panel_labels.html ---
<html>
<head>
</head>
<p>
</p>
<h2>Label Panel</h2>
<p>The <strong>Label</strong> panel lets you place labels and/or legends in the <strong>NVIZ</strong> viewer.</p>
<DEFANGED_IMG src="nvimg/panel/labels.gif" alt="Label Panel" width="286" height="388">
<h3>OPTIONS</h3>
<p>
On the <strong>Label</strong> panel, the first (top) menu has options for setting the font attributes for both the labels and the legend.
</p>
<dl>
<dt> <strong>Font Size</strong></dt>
<dd>Sets the Font size in points.
<br><br></dd>
<dt> <strong>Color</strong></dt>
<dd>Sets the text color.
<br><br></dd>
<dt> <strong>Font</strong></dt>
<dd>Select from one of three font styles.<br><br>
	<dl>
	<dt> <strong>Times-Roman</strong></dt>
	<dd>Sets the font style to Times Roman.
	<br><br></dd>
	<dt> <strong>Helvetica</strong></dt>
	<dd>Sets the font style to Helvetica.
	<br><br></dd>
	<dt> <strong>Courier</strong></dt>
	<dd>Sets the font style to Courier.
	<br><br></dd>
	</dl>
</dd>
<dt> <strong>Font Weight</strong></dt>
<dd>
	<dl>
	<dt> <strong>Bold</strong></dt>
	<dd>Sets the font weight to bold.
	<br><br></dd>
	<dt> <strong>Italics</strong></dt>
	<dd>Sets the font weight to italics.
	<br><br></dd>
	</dl>
</dd>
</dl>
<p>
Use the next menu in the <strong>Label</strong> panel to place labels in the <strong>NVIZ</strong> viewer.
</p>
<dl>
<dt> <strong>Place Label</strong></dt>
<dd>Places the text from <strong>Label Text</strong> in the <strong>NVIZ</strong> viewer using the current font attributes. You click in the <strong>NVIZ</strong> viewer to place the label.
<br><br></dd>
<dt> <strong>Undo</strong></dt>
<dd>Removes the previously defined label from the display list. The label disappears when the <strong>NVIZ</strong> viewer scene redraws.
<br><br></dd>
<dt> <strong>Undo All</strong></dt>
<dd> Removes all labels from the display list.
<br><br></dd>
<dt> <strong>Label Text</strong></dt>
<dd>Enter the text string for the label.
<br><br></dd>
</dl>
<p>
Use the next menu in the <strong>Label</strong> panel to place a surface (raster) legend in the <strong>NVIZ</strong> viewer.
</p>
<dl>
<dt> <strong>Place Legend</strong></dt>
<dd>Places the legend for the current surface (see <a href="nviz_panel_surf.html"> Surface Panel)</a> in the <strong>NVIZ</strong> viewer using the current font attributes.
To define the legend size, you click in the <strong>NVIZ</strong> viewer at the first corner of the legend and right click at the adjacent corner. If the defined box is wider than it is high a horizontal legend is drawn.
<br><br></dd>
<dt> <strong>On</strong></dt>
<dd>Activates the automatic redrawing of the legend. If turned off, the legend is not redrawn.
<br><br></dd>
<dt> <strong>Invert</strong></dt>
<dd>Draws the legend inverted (if selected).
<br><br></dd>
<dt> <strong>Category Values</strong></dt>
<dd>Uses the surface category values as legend labels (if selected).
<br><br></dd>
<dt> <strong>Category Labels</strong></dt>
<dd>Uses the surface category labels as legend labels (if selected).
<br><br></dd>
<dt> <strong>Use Range</strong></dt>
<dd>Uses the defined minimum and maximum when drawing the legend (if selected).
<br><br>
	<dl>
	<dt> <strong>Low</strong></dt>
	<dd>Sets the minimum value of the legend.
	<br><br></dd>
	<dt> <strong>Hi</strong></dt>
	<dd>Sets the maximum value of the legend.
	<br><br></dd>
	</dl>
</dd>
<dt> <strong>Discrete Categories</strong></dt>
<dd>Draws the legend with discrete color breaks.
<br><br></dd>
<dt> <strong>Use List</strong></dt>
<dd>This option is not yet implemented.
<br><br></dd>
</dl>
<p>
Use the next menu in the <strong>Label</strong> panel to draw sites file labels in the <strong>NVIZ</strong> viewer. This menu is not yet implemented.
</p>
<dl>
<dt> <strong>Label Sites</strong></dt>
<br><br></dd>
<dt> <strong>In Box</strong></dt>
<br><br></dd>
<dt> <strong>Values</strong></dt>
<br><br></dd>
<dt> <strong>Labels</strong></dt>
<br><br></dd>
</dl>
</body>
</html>
--- NEW FILE: nviz_panel_pos.html ---
<html>
<head>
</head>
<p>
</p>
<h2>Position Panel</h2>
<p>The <strong>Position</strong> panel lets you manually control the <strong>From</strong> (eye) position and the <strong>To</strong> (surface) position. You can manually enter coordinates or calculate coordinates based upon a range, bearing, and elevation.
</p>
<DEFANGED_IMG src="nvimg/panel/position.gif" alt="Position Panel" width="308" height="194">
<h3>OPTIONS</h3>
<dl>
<dt> <strong>From (eye)</strong></dt>
<dd>Enter coordinates in <strong>GRASS</strong> database units for the <strong>From</strong> (eye) position.<br><br>
	<dl>
	<dt> <strong>East</strong></dt>
	<dd>Enter the easting of the eye position.
	<br><br></dd>
	<dt> <strong>North</strong></dt>
	<dd>Enter the northing of the eye position.
	<br><br></dd>
	<dt> <strong>Ht</strong></dt>
	<dd>Enter the height (elevation) of the eye position.
	<br><br></dd>
	</dl>
</dd>
<dt> <strong>To (surface)</strong></dt>
<dd>Enter coordinates in <strong>GRASS</strong> database units for the <strong>To</strong> (surface) position.<br><br>
	<dl>
	<dd>Enter the easting of the surface position.
	<br><br></dd>
	<dd>Enter the northing of the surface position.
	<br><br></dd>
	<dd>Enter the height (elevation) of the surface position.
	<br><br></dd>
	</dl>
</dd>
<dt> <strong>Range/Bearing</strong></dt>
<dd>Calculates either a new <strong>From</strong> or <strong>To</strong> position based upon a <strong>Range</strong>, <strong>Bearing</strong>, and <strong>Elevation</strong>.
<br><br>
	<dl>
	<dt> <strong>Range</strong></dt>
	<dd>Enter the range (distance) between the eye and surface positions.
	<br><br></dd>
	<dt> <strong>Bearing</strong></dt>
	<dd>Enter the bearing (in degrees) between the eye and surface positions.
	<br><br></dd>
	<dt> <strong>Elev</strong></dt>
	<dd>Enter the elevation (in degrees) between the eye and surface positions.
	<br><br></dd>
	</dl>
</dd>
<dt> <strong>Eye to Surface</strong></dt>
<dd>Uses the  <strong>Range</strong>, <strong>Bearing</strong>, and <strong>Elevation</strong> values to calculate a new <strong>To</strong> position. The <strong>From</strong> position remains unchanged.
<br>
<strong>NOTE:</strong> Use this option with caution, because it is possible to move the surface completely out of view.
<br><br></dd>
<dt> <strong>Surface to Eye</strong></dt>
<dd>Uses the  <strong>Range</strong>, <strong>Bearing</strong>, and <strong>Elevation</strong> values to calculate a new <strong>From</strong> position. The <strong>To</strong> position remains unchanged.
<br><br></dd>
<dt> <strong>Apply</strong></dt>
<dd>Calculates either the new <strong>From</strong> or <strong>To</strong> position (depending on the selected option) and updates coordinates accordingly.
<br><br></dd>
<dt> <strong>Refresh</strong></dt>
<dd>Gets the current <strong>From</strong> and <strong>To</strong> positions from the <strong>Movement</strong> panel.
<br><br></dd>
<dd>Applies the edited <strong>From</strong> and <strong>To</strong> positions to the current view. The <strong>Movement</strong> panel updates to the new position.
<br><br></dd>
<dt> <strong>Close</strong></dt>
<dd>Closes the <strong>Position</strong> panel.
<br><br></dd>
</dl>
</body>
</html>
--- NEW FILE: nviz_panel_scale.html ---
<html>
<head>
</head>
<p>
</p>
<h2>Scale Panel</h2>
<p>The <strong>Scale</strong> panel lets you place scale objects and/or a north arrow in the <strong>NVIZ</strong> viewer.</p>
<DEFANGED_IMG src="nvimg/panel/scale.gif" alt="Scale Panel" width="293" height="253">
<h3>OPTIONS</h3>
<dl>
<dt> <strong>Place Scale Object</strong></dt>
<br><br></dd>
</dl>
<p>
Use one of the next four options to set the type of <strong>Scale object</strong>.
</p>
<dl>
<dt> <strong></strong></dt>
<dd>
	<dl>
	<dt> <strong>Solid</strong></dt>
	<br><br></dd>
	<dt> <strong>Cube</strong></dt>
	<br><br></dd>
	<dt> <strong>Wire</strong></dt>
	<br><br></dd>
	<dt> <strong>Plane</strong></dt>
	<br><br></dd>
	</dl>
</dd>
<dt> <strong>Place Arrow</strong></dt>
<dd>Places a north arrow in the <strong>NVIZ</strong> viewer. You click in the <strong>NVIZ</strong> viewer to place the arrow.
<br><br></dd>
<dt> <strong>North Arrow</strong></dt>
<dd>Activates the automatic redrawing of the north arrow.
<br><br></dd>
</dl>
<p>
<strong>NOTE:</strong> The North arrow is automatically scaled according to scene size and zoom level. There are still some bugs in the scaling which can result in over or under sized arrows.
</p>
<dl>
<dt> <strong>Draw Ruler</strong></dt>
<br><br></dd>
<dd>
	<dl>
	<dt> <strong>NW</strong></dt>
	<br><br></dd>
	<dt> <strong>NE</strong></dt>
	<br><br></dd>
	<dt> <strong>SW</strong></dt>
	<br><br></dd>
	<dt> <strong>SE</strong></dt>
	<br><br></dd>
	</dl>
</dd>
<br><br></dd>
<dt> <strong>Auto</strong></dt>
<br><br></dd>
<dt> <strong>Size</strong></dt>
<br><br></dd>
<br><br></dd>
</dl>
</body>
</html>
Index: nviz_panel_dsf.html
RCS file: /grassrepository/web/gdp/nviz/nviz_panel_dsf.html,v
retrieving revision 1.1
retrieving revision 1.2
diff -u -d -r1.1 -r1.2
--- nviz_panel_dsf.html	23 Jul 2002 08:44:18 -0000	1.1
+++ nviz_panel_dsf.html	26 Mar 2004 16:05:48 -0000	1.2
@@ -1,62 +1,78 @@
 <html>
 <head>
-<title>GRASS 5.0 Tutorial for nviz</title>
- </head>
+   <title>GRASS 5.0 Tutorial for nviz</title>
+</head>
-<P>
-<A HREF="nviz_toc.html">INDEX</A>
-</P>
+<h1><DEFANGED_IMG src="grass.smlogo.gif">NVIZ Reference Manual</h1>
+<hr width="100%" align=center size=4 noshade>
+<p>
+<a href="nviz_toc.html">CONTENTS</a>
+</p>
-<H3>NVIZ - Mkdspf Panel</H3>
-</A> <P>
+<h2>Mkdspf Panel</h2>
-The <A HREF="#MkdspfP">Mkdspf</A> panel provides facilities for
-creating display files (dspf) of isosurfaces from volume data (grid3
-files).  <p>
+<p>
+The <strong>Mkdspf</strong> panel lets you create isosurfaces display files (dspf) from <strong>GRASS</strong> volume data (grid3 files).
+</p>
-<H3>
-<DEFANGED_IMG SRC="nvimg/panel/mkdspf.gif"> <A NAME="MkdspfP">Mkdspf Panel</A>
-</H3> <P>
+<DEFANGED_IMG src="nvimg/panel/mkdspf.gif" alt="Mkdpsf Panel" width="291" height="359">
-<strong>Input File:</em></strong> Enter name of grid3 file from which
-to create isosurfaces.  <p>
+<h3>OPTIONS</h3>
-<strong>Output File:</em></strong> Name of display file
-produced. Should have .dspf extension.  <p>
+<dl>
+<dt> <strong>Input File</strong></dt>
+<dd>Enter the GRASS grid3 file name to use for creating the isosurfaces.
+<br><br></dd>
-<strong>Color File:</em></strong> Another grid3 file from which to
-find color values for isosurfaces.  <p>
+<dt> <strong>Output File</strong></dt>
+<dd>Enter an output display file name (dpsf).
+<br><br></dd>
-<strong>Lighting Model:</em></strong> Choose one of <em>flat
-</em></strong> or <em>gradient </em></strong>. Flat shading is
-somewhat faster in computation and display, but gradient allows
-gouraud shading for isosurfaces with nicer display results.  <p>
+<dt> <strong>Color File</strong></dt>
+<dd>Enter the GRASS grid3 file to use for isosurface color.
+<br><br></dd>
-<strong>Threshold type:</em></strong> Current must be one of
-<em>Complete, Range, or Individual</em></strong>. Click on name of
-current selection to pop up list from which new threshold type can be
-selected. Panel changes depending on Threshold type selected.  <p>
-<strong>Individual:</em></strong>Type in individual threshold
-values. List of selected values will appear in <strong> Iso Levels
-</em></strong> box. Use <strong>add </em></strong>and <strong>delete
-</em></strong>buttons to add or delete current value from list.  <p>
+<dt> <strong>Lighting Model</strong></dt>
+<dd>Lets you select the type of shading used for displaying the isosurfaces.<br><br>
+	<dl>
+	<dt><strong>flat</strong></dt>
+	<dd>Uses flat shading for the isosurfaces. This is the fastest method of shading.
+	<br><br></dd>
+	<dt> <strong>gradient</strong></dt>
+	<dd>Uses gradient (gouraged) shading of the isosurfaces. This is the most realistic shading method.
+	<br><br></dd>
+	</dl>
+</dd>
-<strong>Complete:</em></strong> Type in <strong>Interval Size
-</em></strong>.  Isosurfaces will be computed at Interval-size steps
-from minimum to maximum data values.  <p>
-<strong>Range:</em></strong> Type in values for
-<strong>Min</em></strong>, <strong>Max</em></strong> and <strong>Num
-Levels</em></strong> and select one of the <strong>Interpolation
-</em></strong> toggles: <em>linear</em></strong>
-<em>logarithmic</em></strong> <em>Quadratic</em></strong>
-<em>Arbitrary</em></strong>. The number of levels specified will be
-computed within the range Min to Max, with interval computed according
-to Interpolation method chosen.  <p>
+<dt> <strong>Threshold Type</strong></dt>
+<dd>Displays the threshold menu settings. You select one of the three methods.
+<br><br>
-</BODY>
-</HTML>
\ No newline at end of file
+<ul>
+<li><a href="nviz_panel_dsf1.html"><strong>Individual</strong></a></li>
+<li><a href="nviz_panel_dsf2.html"><strong>Complete</strong></a></li>
+<li><a href="nviz_panel_dsf3.html"><strong>Range</strong></a></li>
+</ul>
+<br><br>
+</dd>
+<dt> <strong>Accept</strong></dt>
+<dd>Uses the current isosurface display parameters to create the display file (dspf).
+<br><br></dd>
+<dt> <strong>Close</strong></dt>
+<dd>Closes the <strong>Mkdspf</strong> panel.
+<br><br></dd>
+</dl>
+</body>
+</html>
Index: nviz_panel_lights.html
RCS file: /grassrepository/web/gdp/nviz/nviz_panel_lights.html,v
--- nviz_panel_lights.html	23 Jul 2002 08:44:18 -0000	1.1
+++ nviz_panel_lights.html	26 Mar 2004 16:05:48 -0000	1.2
@@ -1,68 +1,75 @@
 <html>
 <head>
- </head>
+</head>
-<P>
-</P>
+<p>
+</p>
-<h3>NVIZ - Lights</h3>
-</A> <P>
+<h2>Lighting Panel</h2>
-The <A HREF="#LightP">Lights</A> panel contains adjustments and
-options to control the position, color and brightness of the lights
-and the reflectivity (shininess) of the surface.  There are actually
-two lights: one dim white light remains directly above the surface at
-all times and serves as fill light. The main light, which the user
-controls, is a "local" light which is positioned much like the view
-position.  When lights are being adjusted, a sphere appears on the
-surface and is continuously redrawn to show the effects of lighting
-changes.  The lighting adjustments do not affect the appearance of the
-surface until it is redrawn.  Neither light is directional; light is
-emitted equally in all directions.  <p>
+<p>The <strong>Lighting</strong> panel has options to control the position, color, and brightness of the lights. <strong>NVIZ</strong> uses a fill light and a main light.
+The fill light is a permanent dim white light directly over the surface. The main light controls the shading, which you adjust using the <strong>Lighting</strong> panel. As you adjust the lighting, a lighting model (sphere) appears on the surface and continually shows the effects of the lighting changes.</p>
-<h3>
-<DEFANGED_IMG SRC="nvimg/panel/light.gif"> <A NAME="LightP">Lights Panel</A>
-</h3>  <P>
+<DEFANGED_IMG src="nvimg/panel/light.gif" alt="Light Panel" width="292" height="276">
-<DL>
+<h3>OPTIONS</h3>
-<DT> <B>Follow Viewpoint</B>
-<DD> By default, the light position is near the viewing position and
-the light moves with the viewer.  Toggling this option off will keep
-the light fixed in one position as the viewer position changes.
-Adjusting the <em>Height</em></strong> or <em>XY
-position</em></strong> of the light automatically toggles <em>Follow
-Viewpoint</em></strong> off.  <p>
+<dl>
-<DT> <B>Show Model</B>
-<DD> The sphere showing current lighting effects can be removed by
-toggling this option off.  <p>
+<dt> <strong>Follow Viewpoint</strong></dt>
+<dd> Moves the light position with the view position (if selected).
+By default (off), the light remains fixed at the position set from the <strong>Lighting</strong> panel.
+<br><br></dd>
-<DT> <B>Height</B>
-<DD> Adjusts light height.  <p>
+<dt> <strong>Show Model</strong></dt>
+<dd>Draws the lighting model (sphere) in the viewer. The lighting model shows changes made to lighting parameters.
+<br><br></dd>
-<DT> <B>XY position</B>
-<DD> Adjusts light position over surface; north is always at the top.
-<p>
+<dt> <strong>Brightness</strong></dt>
+<dd>Adjusts the brightness of the main light.
+<br><br></dd>
-<DT> <B>Light Brightness</B>
-<DD> Adjusts the brightness of the light.  <p>
+<dt> <strong>Ambient</strong></dt>
+<dd> Adjusts the ambient light associated with the main light and the
+brightness of the fill light.
+<br><br></dd>
-<DT> <B>R, G, B</B>
-<DD> Adjusts the Red, Green and Blue components of the main light.
-<p>
+<dt> <strong>Height</strong></dt>
+<dd>Adjusts the main light height.<br><br></dd>
-<DT> <B>Ambient Light</B>
-<DD> Adjusts the ambient light associated with the main light and the
-brightness of the fill light. <p>
+<dt> <strong>Red</strong></dt>
+<dd> Adjusts the amount of Red in the main light.
+<br><br></dd>
-</DL>
- <P>
+<dt> <strong>Green</strong></dt>
+<dd> Adjusts the amount of Green in the main light.
+<br><br></dd>
-</BODY>
-</HTML>
+<dt> <strong>Blue</strong></dt>
+<dd> Adjusts the amount of Blue in the main light.
+<br><br></dd>
+<dt> <strong>Position Box</strong></dt>
+<dd> Adjusts the main light direction.
+Click and drag the puck to change the light direction.
+The box annotations are <strong><em>N</em></strong>orth, <strong><em>S</em></strong>outh, <strong><em>E</em></strong>ast, and <strong><em>W</em></strong>est.
+<br><br></dd>
+<dd> Closes the <strong>Lighting</strong> panel.
+<br><br></dd>
+</dl>
+</body>
+</html>
Index: nviz_panel_move.html
RCS file: /grassrepository/web/gdp/nviz/nviz_panel_move.html,v
--- nviz_panel_move.html	23 Jul 2002 08:44:18 -0000	1.1
+++ nviz_panel_move.html	26 Mar 2004 16:05:48 -0000	1.2
@@ -2,115 +2,93 @@
 <head>
- </head>
+<title>NVIZ Manual</title>
+</head>
-<P>
-</P>
+<p>
+</p>
-<h3>NVIZ - Movement</h3>
-</A><p>
+<h2>Movement Panel</h2>
-<em>nviz</em></strong> starts up with one graphics window and one
-control panel window.  The top third of the control panel window
-contains the <a href="#MovementP"> Movement </a> panel.  Other panels
-may be selected from the <em>Panel</em></strong> menu at the top of
-the window. When a panel is selected it appears in the control panel
-window.  If the window is full, and there is no room for the new
-panel, one or more panels that are open on the control panel window
-will be closed to make room for the new panel.  Panels can also be
-closed using the <em>Close</em></strong> button that appears on each
-panel.  The <em>Movement panel</em>, however is always visible. Each
-panel from the <em>Panel</em></strong> menu will be described in more
-detail below.  <p>
+<p>The <strong>Movement</strong> panel always appears at the top of the <strong>Controls</strong> window. You use the <strong>Movement</strong> panel to set the position, direction, and perspective of the view. As you change movement options, a low resolution or wire grid of the surface redraws (<strong><em>fast display mode</em></strong>) showing the results of your changes.</p>
-<h3>
-<DEFANGED_IMG SRC="nvimg/panel/main.gif" ALT = ""> <A name="MovementP">Movement Panel</A>
-</h3><p>
+<DEFANGED_IMG src="nvimg/panel/main.gif" alt = "Movement Panel" width="302" height="323">
-Use the <strong>Movement</em></strong> panel to position the viewer
-over the data and to indicate viewing direction and perspective.  As
-options in this panel are changed, a wire grid of the surface is
-redrawn (<em>fast display mode</em></strong>) to immediately show the
-results of the changes.  This panel also controls the actual drawing.
- <P>
+<h3>OPTIONS</h3>
-<DL>
-<DT> <B>Auto Clear</B>
-<DD> This is a toggle button. If it is enabled
-the screen is automatically cleared before surfaces are drawn.  <P>
+<dl>
+<dt> <strong>Auto: Clear</strong></dt>
+<dd>Clears the screen before drawing the surfaces (if selected).<br><br></dd>
-<DT> <B>Clear</B>
-<DD> Clears the screen with the background color.  <P>
+<dt> <strong>Auto: Draw</strong></dt>
+<dd>Redraws the scene each time the view changes (if selected).<br><br></dd>
+<dt> <strong>Feature: Surface</strong></dt>
+<dd>Draws all loaded surfaces (if selected).<br><br></dd>
-<DT> <B>Surface</B>
-<DD> Draws loaded surfaces with current drawing
-and lighting options.  <P>
+<dt> <strong>Feature: Vectors</strong></dt>
+<dd>Draws all loaded vectors (if selected).<br><br></dd>
+<dt> <strong>Feature: Sites</strong></dt>
+<dd>Draws all loaded sites files (if selected).<br><br></dd>
-<DT> <B>Vectors</B>
-<DD> Draws loaded vector files on selected
-surfaces.  <P>
+<dt> <strong>Draw</strong></dt>
+<dd>Draws selected files using the current viewing and lighting options.<br><br></dd>
-<DT> <B>Sites</B>
-<DD> Draws loaded site files on selected surfaces.
-<P>
+<dt> <strong>Clear</strong></dt>
+<dd>Clears the screen to the background color.<br><br></dd>
-<DT> <B>Cancel</B>
-<DD> Cancels drawing in progress.  <p>
+<dt> <strong>Cancel</strong></dt>
+<dd>Cancels the drawing in progress.<br><br></dd>
-<DD> The <em>XY position</em></strong> box contains a star-shaped puck
-which represents the viewer.  Click on the puck and drag to move the
-viewer around.  The data may be thought of as always lying in the
-center of the box, with north at the top. <p>
+<dt> <strong>View: eye</strong></dt>
+<dd>Sets the position box (directly below) to control the eye position of the view. The view center remains unchanged.<br><br></dd>
-<DT> <B>Height</B>
-<DD> Adjusts the viewer's height.  <p>
+<dt> <strong>View: center</strong></dt>
+<dd>Sets the position box (directly below) to control the view center position. The eye position remains unchanged.<br><br></dd>
-<DT> <B>look here</B>
-<DD> Allows the user to click on a spot on the data surface which will
-remain centered as the viewer position changes.  After clicking on the
-surface, the new center is automatically set and the surface is
-redrawn.  <p>
+<dd>If the <strong><em>eye</em></strong> view is selected, the position box shows a puck with a direction arrow pointing to the center. The direction arrow indicates the look direction (azimuth). You click and drag the puck to change the current eye position. The box annotations are <strong><em>N</em></strong>orth, <strong><em>S</em></strong>outh, <strong><em>E</em></strong>ast, and <strong><em>W</em></strong>est.
+<br><br>
+If the <strong><em>center</em></strong> view is selected, the position box shows as a cross hair. You click and drag the cross hair to change the current center of view.<br><br></dd>
-<DT> <B>look center</B>
-<DD> Automatically fixes new center of view at the <em>center of the
-graphics window</em></strong> (not the center of the data).  <p>
-<DT> <B>look cancel</B>
-<DD> Clicking on <em>cancel</em></strong> allows the user to move over
-the surface with no fixed center of view (default).  <p>
+<dd> Adjusts the viewer's height above the scene.<br><br></dd>
-<DT> <B>zexag</B>
-<DD> Exaggerates the vertical dimension of the surface.  An
-exaggeration of 1.0 represents the surface with x, y, and z units all
-being equal.  For example, if the easting and northing units are in
-meters and the elevation in feet, a Z exaggeration of .305 would be
-the <em>true</em></strong> exaggeration for the surface.  For most
-geographical applications, greater than true exaggeration produces
-more visually pleasing images.  <p>
+<dt> <strong>zexag</strong></dt>
+<dd> Adjusts the vertical exaggeration of the surface. As an example, if the easting and northing are in meters and the elevation in feet, a vertical exaggeration of .305 would produce a true (unexaggerated) surface. <br><br></dd>
-<DT> <B>Perspective</B>
-<DD> Adjusts the viewer's angle of view.  <p>
+<dt> <strong>Look here</strong></dt>
+<dd> Allows you to select a point on the surface that becomes the new center of view.
+<br><br></dd>
-<DT> <B>Reset</B>
-<DD> Sets all settings to their startup values.  <p>
+<dt> <strong>Look center</strong></dt>
+<dd>Resets the view to the original default center of view.
+<br><br></dd>
-</DL>
-<P>
+<dt> <strong>Look top</strong></dt>
+<dd>Sets the viewer directly over the scene's center position. This <strong><em>top</em></strong> view orients approximately north south.<br><br></dd>
-Occasionally, the bounds of the <B>height</B> slider are too narrow to
-position the camera as desired.  In this case, the type-in entry next
-to the height slider may be used to set camera height directly.
-Typing in a value will also automatically adjust the slider bounds to
-account for the new maximum and minimum height.  In general, most
-sliders with corresponding type-ins provide this functionality where
-it makes sense.  Color sliders, for example, cannot be adjusted since
-color components must always be between 0.0 and 1.0.
- <P>
+<dt> <strong>Look cancel</strong></dt>
+<dd> Allows you to move over the surface with no center of view.
+<br><br></dd>
-</BODY>
-</HTML>
+<dt> <strong>perspective</strong></dt>
+<dd> Adjusts the viewer's angle of view.<br><br></dd>
+ <dt> <strong>twist</strong></dt>
+<dd> Rotates the scene about the horizontal axis. An angle of 0 is flat. The scene rotates between -90 and 90 degrees.<br><br></dd>
+<dt> <strong>RESET</strong></dt>
+<dd>Returns all current settings to their startup values.<br><br></dd>
+</dl>
+</body>
+</html>
More information about the grass-web mailing list
