[GRASSweb-list]markus: web/bugtracking bugreport.html,1.27,1.28
grass at intevation.de grass at intevation.de
Tue May 4 06:15:05 EDT 2004
Author: markus
Update of /grassrepository/web/bugtracking
In directory doto:/tmp/cvs-serv16133
Modified Files:
	bugreport.html
Log Message:
added 5.3
Index: bugreport.html
RCS file: /grassrepository/web/bugtracking/bugreport.html,v
retrieving revision 1.27
retrieving revision 1.28
diff -u -d -r1.27 -r1.28
--- bugreport.html	11 Nov 2003 00:53:01 -0000	1.27
+++ bugreport.html	4 May 2004 10:15:03 -0000	1.28
@@ -20,7 +20,7 @@
 <p>
 <ul>
 <li> Only report if using at least the current stable release version
-(GRASS 5.0.3 was released 06 November 2003).
+(GRASS 5.0.3 was released 06 November 2003), but preferably 5.3.
 If you use an older version, please consider to <a href=../download.html>upgrade</a>.
 <li> Before reporting a bug, please check that it is currently unkown:
@@ -56,8 +56,8 @@
 <th align=left>Type of report: </th>
 <td>
 	<select name="area">
-	<option value="bug">bug (5.0)
-	<option value="wish">wish (5.0)
+	<option value="bug">bug (5.0/5.3)
+	<option value="wish">wish (5.0/5.3)
         <option value="grass5.7">grass5.7
 	</select>
 </td>
More information about the grass-web mailing list
