markus: web/grass53/source/snapshot_experimental COPYRIGHT.html,NONE,1.1 README.html,NONE,1.1 compiling.html,NONE,1.1
grass at intevation.de grass at intevation.de
Fri May 21 04:55:32 EDT 2004
Author: markus
Update of /grassrepository/web/grass53/source/snapshot_experimental
In directory doto:/tmp/cvs-serv6207
Added Files:
	COPYRIGHT.html README.html compiling.html
Log Message:
moved here from ../../grass50/source/
--- NEW FILE: COPYRIGHT.html ---
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
   <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
   <title>GRASS GIS released under GNU Public License </title>
</head>
<body bgcolor="#FFFFFF">
<pre>
Copyright and License Statement
Geographic Resources Analysis Support System (GRASS) is Copyright,
1999-2004 by the GRASS Development Team, and licensed under terms of the
GNU General Public License (GPL).
Parts of GRASS are not copyright by the GRASS development team.
The original authors hold the copyrights and you have to abide
to their licensing terms where noted.
(Keep in mind that code linking into GRASS can only be distributed
if compatible with the GPL.)
GRASS development is coordinated by the GRASS Development Team
headquartered at ITC-irst (Trento, Italy) with contributions from
all over the world.
This program is free software; you can redistribute it and/or modify it
under the terms of the GNU General Public License as publishe by the
Free Software Foundation; either version 2 of the License, or (at your
option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
GNU General Public License (GPL) for more details.
You should have received a copy of the GNU General Public License
along with this program; if not, write to the
  Free Software Foundation, Inc.,
  59 Temple Place - Suite 330,
  Boston, MA  02111-1307, USA.
Questions regarding GRASS GIS should be directed to the
GRASS Development Team at the following address:
 ITC-Irst
 c/o M. Neteler
 SSI/MPA
 Via Sommarive, 18
 38050 Trento (Povo)
 Italy
 neteler at itc.it
Internet:  http://grass.itc.it
           http://grass.ibiblio.org
GNU GENERAL PUBLIC LICENSE
Version 2, June 1991
Copyright (C) 1989, 1991 Free Software Foundation, Inc.
59 Temple Place - Suite 330, Boston, MA  02111-1307, USA
Everyone is permitted to copy and distribute verbatim copies of this license
document, but changing it is not allowed.
Preamble
The licenses for most software are designed to take away your freedom to
share and change it. By contrast, the GNU General Public License is intended
to guarantee your freedom to share and change free software--to make sure
the software is free for all its users. This General Public License applies
to most of the Free Software Foundation's software and to any other program
whose authors commit to using it. (Some other Free Software Foundation
software is covered by the GNU Library General Public License instead.) You
can apply it to your programs, too.
When we speak of free software, we are referring to freedom, not price. Our
General Public Licenses are designed to make sure that you have the freedom
to distribute copies of free software (and charge for this service if you
wish), that you receive source code or can get it if you want it, that you
can change the software or use pieces of it in new free programs; and that
you know you can do these things.
To protect your rights, we need to make restrictions that forbid anyone to
deny you these rights or to ask you to surrender the rights. These
restrictions translate to certain responsibilities for you if you distribute
copies of the software, or if you modify it.
For example, if you distribute copies of such a program, whether gratis or
for a fee, you must give the recipients all the rights that you have. You
must make sure that they, too, receive or can get the source code. And you
must show them these terms so they know their rights.
We protect your rights with two steps: (1) copyright the software, and (2)
offer you this license which gives you legal permission to copy, distribute
and/or modify the software.
Also, for each author's protection and ours, we want to make certain that
everyone understands that there is no warranty for this free software. If
the software is modified by someone else and passed on, we want its
recipients to know that what they have is not the original, so that any
problems introduced by others will not reflect on the original authors'
reputations.
Finally, any free program is threatened constantly by software patents. We
wish to avoid the danger that redistributors of a free program will
individually obtain patent licenses, in effect making the program
proprietary. To prevent this, we have made it clear that any patent must be
licensed for everyone's free use or not licensed at all.
The precise terms and conditions for copying, distribution and modification
follow.
TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION
0. This License applies to any program or other work which contains a notice
placed by the copyright holder saying it may be distributed under the terms
of this General Public License. The "Program", below, refers to any such
program or work, and a "work based on the Program" means either the Program
or any derivative work under copyright law: that is to say, a work
containing the Program or a portion of it, either verbatim or with
modifications and/or translated into another language. (Hereinafter,
translation is included without limitation in the term "modification".) Each
licensee is addressed as "you".
Activities other than copying, distribution and modification are not covered
by this License; they are outside its scope. The act of running the Program
is not restricted, and the output from the Program is covered only if its
contents constitute a work based on the Program (independent of having been
made by running the Program). Whether that is true depends on what the
Program does.
1. You may copy and distribute verbatim copies of the Program's source code
as you receive it, in any medium, provides that you conspicuously and
appropriately publish on each copy an appropriate copyright notice and
disclaimer of warranty; keep intact all the notices that refer to this
License and to the absence of any warranty; and give any other recipients of
the Program a copy of this License along with the Program.
You may charge a fee for the physical act of transferring a copy, and you
may at your option offer warranty protection in exchange for a fee.
2. You may modify your copy or copies of the Program or any portion of it,
thus forming a work based on the Program, and copy and distribute such
modifications or work under the terms of Section 1 above, provided that you
also meet all of these conditions:
     a) You must cause the modified files to carry prominent notices stating
that you changed the files and the date of any change.
     b) You must cause any work that you distribute or publish, that in
whole or in part contains or is derived from the Program or any part
thereof, to be licensed as a whole at no charge to all third parties under
the terms of this License.
     c) If the modified program normally reads commands interactively when
run, you must cause it, when started running for such interactive use in the
most ordinary way, to print or display an announcement including an
appropriate copyright notice and a notice that there is no warranty (or
else, saying that you provide a warranty) and that users may redistribute
the program under these conditions, and telling the user how to view a copy
of this License. (Exception: if the Program itself is interactive but does
not normally print such an announcement, your work based on the Program is
not required to print an announcement.)
These requirements apply to the modified work as a whole. If identifiable
sections of that work are not derived from the Program, and can be
reasonably considered independent and separate works in themselves, then
this License, and its terms, do not apply to those sections when you
distribute them as separate works. But when you distribute the same sections
as part of a whole which is a work based on the Program, the distribution of
the whole must be on the terms of this License, whose permissions for other
licensees extend to the entire whole, and thus to each and every part
regardless of who wrote it.
Thus, it is not the intent of this section to claim rights or contest your
rights to work written entirely by you; rather, the intent is to exercise
the right to control the distribution of derivative or collective works
based on the Program.
In addition, mere aggregation of another work not based on the Program with
the Program (or with a work based on the Program) on a volume of a storage
or distribution medium does not bring the other work under the scope of this
License.
3. You may copy and distribute the Program (or a work based on it, under
Section 2) in object code or executable form under the terms of Sections 1
and 2 above provided that you also do one of the following:
     a) Accompany it with the complete corresponding machine-readable source
code, which must be distributed under the terms of Sections 1 and 2 above on
a medium customarily used for software interchange; or,
     b) Accompany it with a written offer, valid for at least three years,
to give any third party, for a charge no more than your cost of physically
performing source distribution, a complete machine-readable copy of the
corresponding source code, to be distributed under the terms of Sections 1
and 2 above on a medium customarily used for software interchange; or,
     c) Accompany it with the information you received as to the offer to
distribute corresponding source code. (This alternative is allowed only for
noncommercial distribution and only if you received the program in object
code or executable form with such an offer, in accord with Subsection b
above.)
The source code for a work means the preferred form of the work for making
modifications to it. For an executable work, complete source code means all
the source code for all modules it contains, plus any associated interface
definition files, plus the scripts used to control compilation and
installation of the executable. However, as a special exception, the source
code distributed need not include anything that is normally distributed (in
either source or binary form) with the major components (compiler, kernel,
and so on) of the operating system on which the executable runs, unless that
component itself accompanies the executable.
If distribution of executable or object code is made by offering access to
copy from a designated place, then offering equivalent access to copy the
source code from the same place counts as distribution of the source code,
even though third parties are not compelled to copy the source along with
the object code.
4. You may not copy, modify, sublicense, or distribute the Program except as
expressly provided under this License. Any attempt otherwise to copy,
modify, sublicense or distribute the Program is void, and will automatically
terminate your rights under this License. However, parties who have received
copies, or rights, from you under this License will not have their licenses
terminated so long as such parties remain in full compliance.
5. You are not required to accept this License, since you have not signed
it. However, nothing else grants you permission to modify or distribute the
Program or its derivative works. These actions are prohibited by law if you
do not accept this License. Therefore, by modifying or distributing the
Program (or any work based on the Program), you indicate your acceptance of
this License to do so, and all its terms and conditions for copying,
distributing or modifying the Program or works based on it.
6. Each time you redistribute the Program (or any work based on the
Program), the recipient automatically receives a license from the original
licensor to copy, distribute or modify the Program subject to these terms
and conditions. You may not impose any further restrictions on the
recipients' exercise of the rights granted herein. You are not responsible
for enforcing compliance by third parties to this License.
7. If, as a consequence of a court judgment or allegation of patent
infringement or for any other reason (not limited to patent issues),
conditions are imposed on you (whether by court order, agreement or
otherwise) that contradict the conditions of this License, they do not
excuse you from the conditions of this License. If you cannot distribute so
as to satisfy simultaneously your obligations under this License and any
other pertinent obligations, then as a consequence you may not distribute
the Program at all. For example, if a patent license would not permit
royalty-free redistribution of the Program by all those who receive copies
directly or indirectly through you, then the only way you could satisfy both
it and this License would be to refrain entirely from distribution of the
Program.
If any portion of this section is held invalid or unenforceable under any
particular circumstance, the balance of the section is intended to apply and
the section as a whole is intended to apply in other circumstances.
It is not the purpose of this section to induce you to infringe any patents
or other property right claims or to contest validity of any such claims;
this section has the sole purpose of protecting the integrity of the free
software distribution system, which is implemented by public license
practices. Many people have made generous contributions to the wide range of
software distributed through that system in reliance on consistent
application of that system; it is up to the author/donor to decide if he or
she is willing to distribute software through any other system and a
licensee cannot impose that choice.
This section is intended to make thoroughly clear what is believed to be a
consequence of the rest of this License.
8. If the distribution and/or use of the Program is restricted in certain
countries either by patents or by copyrighted interfaces, the original
copyright holder who places the Program under this License may add an
explicit geographical distribution limitation excluding those countries, so
that distribution is permitted only in or among countries not thus excluded.
In such case, this License incorporates the limitation as if written in the
body of this License.
9. The Free Software Foundation may publish revised and/or new versions of
the General Public License from time to time. Such new versions will be
similar in spirit to the present version, but may differ in detail to
address new problems or concerns.
Each version is given a distinguishing version number. If the Program
specifies a version number of this License which applies to it and "any
later version", you have the option of following the terms and conditions
either of that version or of any later version published by the Free
Software Foundation. If the Program does not specify a version number of
this License, you may choose any version ever published by the Free Software
Foundation.
10. If you wish to incorporate parts of the Program into other free programs
whose distribution conditions are different, write to the author to ask for
permission. For software which is copyrighted by the Free Software
Foundation, write to the Free Software Foundation; we sometimes make
exceptions for this. Our decision will be guided by the two goals of
preserving the free status of all derivatives of our free software and of
promoting the sharing and reuse of software generally.
NO WARRANTY
11. BECAUSE THE PROGRAM IS LICENSED FREE OF CHARGE, THERE IS NO WARRANTY FOR
THE PROGRAM, TO THE EXTENT PERMITTED BY APPLICABLE LAW. EXCEPT WHEN
OTHERWISE STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR OTHER PARTIES
PROVIDE THE PROGRAM "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED
OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK AS TO
THE QUALITY AND PERFORMANCE OF THE PROGRAM IS WITH YOU. SHOULD THE PROGRAM
PROVE DEFECTIVE, YOU ASSUME THE COST OF ALL NECESSARY SERVICING, REPAIR OR
CORRECTION.
12. IN NO EVENT UNLESS REQUIRED BY APPLICABLE LAW OR AGREED TO IN WRITING
WILL ANY COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MAY MODIFY AND/OR
REDISTRIBUTE THE PROGRAM AS PERMITTED ABOVE, BE LIABLE TO YOU FOR DAMAGES,
INCLUDING ANY GENERAL, SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES ARISING
OUT OF THE USE OR INABILITY TO USE THE PROGRAM (INCLUDING BUT NOT LIMITED TO
LOSS OF DATA OR DATA BEING RENDERED INACCURATE OR LOSSES SUSTAINED BY YOU OR
THIRD PARTIES OR A FAILURE OF THE PROGRAM TO OPERATE WITH ANY OTHER
PROGRAMS), EVEN IF SUCH HOLDER OR OTHER PARTY HAS BEEN ADVISED OF THE
POSSIBILITY OF SUCH DAMAGES.
END OF TERMS AND CONDITIONS
</pre>
</body>
</html>
--- NEW FILE: README.html ---
<html>
<head>
<title>GRASS GIS 5.3-cvs CVS experimental tree snapshot</title>
</head>
<h2>GRASS GIS 5.3-cvs CVS experimental tree (HEAD) snapshot</h2>
This directory contains the weekly generated CVS snapshot of
the experimental tree (HEAD).
<p>
<b>What's that?</b><p>
If you are not interested to use the CVS program for directly accessing the
latest GRASS 5.3-cvs source code, you can follow ongoing development by download a
source code from <b>here</b>. This CVS snapshot is the source code checked
out from CVS experimental tree (HEAD) repository once a week.
<p>
If you are interested in very latest code, please access directly the
<a href=../../../grasscvs.html>CVS server</a> for latest GRASS 5.3-cvs sources.
<h2>Is this snapshot stable?</h2>
No.
<p>
>From time to time regular "GRASS 5.x releases" will be officially published.
<p>
Note: The required space for a full compilation is 340MB
      (including object.files etc). The resulting binary package
      size is between 60MB and 100MB depending on your platform.
<h2>Bug reports</h2>
Please report bugs *if* not listed in Known BUGS.
You are encouraged to use our bug report form:
<a href=../../../bugtracking/bugreport.html>bug report form</a>
<p>
Improvements and source code pieces are very welcome!
<hr>
Go here for <a href=../README.html>compilation hints</a>
<hr>
<address>GRASS Development Team</address>
</body>
</html>
--- NEW FILE: compiling.html ---
<HTML> <pre>
Date: $Date: 2004/05/21 08:55:30 $
This directory contains the experimental (HEAD) source code for
GRASS GIS 5.3.X in gzipped tar format.
It reflects latest development!
The large (around 23 mb) file grass53src_cvs_snapshot_exp_YYYY_MM_DD.tar.gz is
 the whole source in a single file.  Get this file.  The file name indicates
the date that the snapshot was made, in the format YYYY_MM_DD, where YYYY
is the year, MM is the month, and DD is the date, as integers.
To extract do following:
- Create a directory for the source code:
  Example:
        mkdir /opt/grass53sources
- Put the package there and extract it (replace "YYYY_MM_DD" with
  the the date of your snapshot from the name of the file you downloaded,
  as described above):
        gunzip grass53src_cvs_snapshot_exp_YYYY_MM_DD.tar.gz
	tar -xvf grass53src_cvs_snapshot_exp_YYYY_MM_DD.tar
  Example:
        gunzip grass53src_cvs_snapshot_exp_2004_02_14.tar.gz
        tar -xvf grass53src_cvs_snapshot_exp_2004_02_14.tar
This will create the necessary directories and
files for you to compile GRASS.
Compile the source:
-> Please read the included INSTALL text for details!
   It contains the latest instructions.
A) If you have "root" access to your machine:
  Jump into the new directory "grass53_exp_YYYY_MM_DD", again substituting
	the date of your snapshot for YYYY_MM_DD (example):
        cd grass53_exp_2004_02_14
  To compile enter following:
        ./configure <parameters>
        make
        make install
  Again: read the INSTALL file in the sources!
  Now the code will be compiled (takes around 1h depending on
  processor's speed).
B) If you have no "root" access: You can also compile
   GRASS locally (replace "user" with your username):
   Jump into the new directory "53_exp_YYYY_MM_DD", again substituting
   Then start the process:
        ./configure --prefix=/home/user/grass53 --with-bindir=/home/user
        make
        make install
   This will store the GRASS binaries into your local directory
   "grass53" and the start script into your home.
  Example:
        ./configure --prefix=/home/roberta/grass53 --with-bindir=/home/roberta
        make
        make install
  processor's speed).
The "configure" process creates two scripts (they will be stored in
/usr/local/bin/ after running "make install" if not having used configure
with option "--with-bindir")
   gmake5
   gmakelinks5
To (later) compile a single GRASS module, run within the related
directory
   gmake5 -i
   gmakelinks5 -i
And don't forget:
Enjoy ongoing GRASS development!
If you experience any problems, please email
us at the GRASS Developers mailing list:
http://grass.itc.it/grassdevel.html
Report bugs to (if not listed in "know_bugs"):
http://grass.itc.it/bugtracking/bugreport.html
Send improvements to
Thanks!
</pre>
Get this <a href=compiling.html>file.</a>
</HTML>
More information about the grass-web mailing list
