[GRASSweb-list]link http://mpa.itc.it/radim/g51/g51test-12.tar.gz is broken
Markus Neteler
neteler at itc.it
Mon Nov 8 13:03:20 EST 2004
On Thu, Nov 04, 2004 at 09:28:29AM -0500, Li, Huimin wrote:
> <http://mpa.itc.it/radim/g51/g51test-12.tar.gz> Link of:
> http://mpa.itc.it/radim/g51/g51test-12.tar.gz is broken.
> Can't load the GRASS5.7 sample location for the tutorial.
> Could you kindly send me the sample location file ?
This data set is no longer available as it is not compliant
with the current state of GRASS 5.7. Maybe in future we
can make it available again.
Regards
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
More information about the grass-web
