[GRASSweb-list]error message
Markus Neteler neteler at itc.it
Mon Nov 22 06:42:52 EST 2004
On Sun, Nov 21, 2004 at 11:24:31PM +0200, bms wrote:
> I couldn't run the grass5.3.0 because when i did ./configure after gunzip command i got error message : unable to locate Tcl includes.
> with my best regards
> Eng . MHD Bashar Erabi
You have to install several packages to compile GRASS.
Please see the REQUIREMENTS.html file in the source code package.
Regards
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
More information about the grass-web mailing list
