[GRASSweb-list]hamish: web/grass57/binary/mswindows_cygwin cygwin_grass.html,1.2,1.3
grass at intevation.de grass at intevation.de
Mon Oct 11 21:41:15 EDT 2004
Author: hamish
Update of /grassrepository/web/grass57/binary/mswindows_cygwin
In directory doto:/tmp/cvs-serv20865/web/grass57/binary/mswindows_cygwin
Modified Files:
	cygwin_grass.html
Log Message:
add note about the X.org X-Window system needing the XFree86-lib-compat package
Index: cygwin_grass.html
RCS file: /grassrepository/web/grass57/binary/mswindows_cygwin/cygwin_grass.html,v
retrieving revision 1.2
retrieving revision 1.3
diff -u -d -r1.2 -r1.3
--- cygwin_grass.html	29 Mar 2004 16:44:34 -0000	1.2
+++ cygwin_grass.html	12 Oct 2004 01:41:13 -0000	1.3
@@ -65,9 +65,14 @@
   libtiff4, login, man, ncurses, opengl, openssh, perl, postgresql, readline, regex, sed,
   sh-utils/shellutils, sunrpc, tar, tcsh, termcap, texinfo, textutils,
   tiff, time, unzip, w32api, zip, zlib.<br>
-   Additionally you may want to keep the selected XFree Server packages
-   (check the XFree section to fetch all required packages), if you
-   don't want to use other X Window software.
+   <br>
+   Additionally you will probably want to keep the selected XFree Server packages
+   selected if you are not already using other X-Window software (check the XFree
+   section to fetch all required packages).
+   Newer versions of Cygwin make use of X-Windows from X.org; if you are
+   installing these be sure to install the XFree86-lib-compat package as well.
   <li> <i>Then 'Next'.</i> This will now download all stuff... takes time...
 </ul>
 <li> Then the installation is performed. Finally <i>press 'Finish'</i><br>
More information about the grass-web mailing list
