[GRASSweb-list]markus: web i18n.html,1.7,1.8
grass at intevation.de
Fri Oct 22 06:29:10 EDT 2004
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv28368
Modified Files:
i18n.html
Log Message:
small fix
Index: i18n.html
RCS file: /grassrepository/web/i18n.html,v
retrieving revision 1.7
retrieving revision 1.8
diff -u -d -r1.7 -r1.8
--- i18n.html 21 Oct 2004 11:37:20 -0000 1.7
+++ i18n.html 22 Oct 2004 10:29:08 -0000 1.8
@@ -48,6 +48,7 @@
<li>get a fresh (!) GRASS 5.7 from <a href=http://freegis.org/grass/grass-cvs.html>CVS</a>
(or <a href=grass57/source/snapshot/>5.7 CVS snapshot</a> which also
requires the <a href=grass53/source/snapshot_experimental/>5.3 CVS snapshot</a>)
+<li>run: '<tt>cd locale</tt>' to change into the translation directory
<li>run: '<tt>make pot</tt>' to create grass*.pot files (containing original messages)
<li>run: '<tt>make update-po</tt>' merge new messages into existing *.po files (or create new po files)
<li>Now translate the messages in the po/*.po files (using kbabel or other editor)
More information about the grass-web
