[GRASSweb-list]bernhard: web firsttime.html,1.34,1.35 grassdevel.html,1.43,1.44
grass at intevation.de grass at intevation.de
Mon Sep 27 11:26:49 EDT 2004
Author: bernhard
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv12279
Modified Files:
	firsttime.html grassdevel.html
Log Message:
Update links to GRASS 5 Programmer's Manual:
	from grass5/progmangrass50.pdf to grass50/progmangrass50.pdf
Index: firsttime.html
RCS file: /grassrepository/web/firsttime.html,v
retrieving revision 1.34
retrieving revision 1.35
diff -u -d -r1.34 -r1.35
--- firsttime.html	19 May 2004 15:19:13 -0000	1.34
+++ firsttime.html	27 Sep 2004 15:26:47 -0000	1.35
@@ -218,7 +218,7 @@
 <li>As GRASS is an open source GIS, so you have full access. We suggest that you get a fresh copy from
 the <a href="grasscvs.html">GRASS CVS repository</a>.
 <br>Consider to subscribe to the GRASS <a href="grassdevel.html">Developers mailing list</a>.&nbsp;
-A draft GRASS 5 Programmer's Manual is available <a href="grass5/progmangrass50.pdf">here</a>.
+A draft GRASS 5 Programmer's Manual is available <a href="./grass50/progmangrass50.pdf">here</a>.
 <p>
 <li>If you would like to take part in the GRASS Development. See also the
 <a href="grassdevel.html">"What you can do for GRASS"</a> page.</ul>
Index: grassdevel.html
RCS file: /grassrepository/web/grassdevel.html,v
retrieving revision 1.43
retrieving revision 1.44
diff -u -d -r1.43 -r1.44
--- grassdevel.html	19 May 2004 15:19:13 -0000	1.43
+++ grassdevel.html	27 Sep 2004 15:26:47 -0000	1.44
@@ -152,7 +152,7 @@
 <li><b>GRASS 5.0:</b>
 <ul>
   <li>GRASS 5.0 Programmer's Manual [ <a
-   href=grass5/progmangrass50.pdf>PDF</a>, 2.3 MB |
+   href=./grass50/progmangrass50.pdf>PDF</a>, 2.3 MB |
    <a href=http://mpa.itc.it/markus/grass50progman/>HTML</a> ]
    <br>You can also access the latest Latex sources of the "GRASS 5.0
    Programmer's Manual" from our <a href="grasscvs.html#progman">CVS server</a>.
More information about the grass-web mailing list
