[GRASSweb-list]markus: web grassdevel.html,1.44,1.45
grass at intevation.de grass at intevation.de
Thu Sep 30 05:48:13 EDT 2004
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv26636
Modified Files:
	grassdevel.html
Log Message:
upgraded progman version
Index: grassdevel.html
RCS file: /grassrepository/web/grassdevel.html,v
retrieving revision 1.44
retrieving revision 1.45
diff -u -d -r1.44 -r1.45
--- grassdevel.html	27 Sep 2004 15:26:47 -0000	1.44
+++ grassdevel.html	30 Sep 2004 09:48:11 -0000	1.45
@@ -149,9 +149,9 @@
 <a name=prog></a>
 <h2>GRASS 5 Programmer's Manual</h2>
 <ul>
-<li><b>GRASS 5.0:</b>
+<li><b>GRASS 5.0/5.3:</b>
 <ul>
-  <li>GRASS 5.0 Programmer's Manual [ <a
+  <li>GRASS 5.0/5.3 Programmer's Manual [ <a
    href=./grass50/progmangrass50.pdf>PDF</a>, 2.3 MB |
    <a href=http://mpa.itc.it/markus/grass50progman/>HTML</a> ]
    <br>You can also access the latest Latex sources of the "GRASS 5.0
More information about the grass-web mailing list
