[GRASSweb-list]markus: web/grass61/binary/linux README.html,NONE,1.1
grass at intevation.de grass at intevation.de
Thu Apr 14 04:58:02 EDT 2005
Author: markus
Update of /grassrepository/web/grass61/binary/linux
In directory doto:/tmp/cvs-serv3391
Added Files:
	README.html
Log Message:
added GRASS 6.1 structure
--- NEW FILE: README.html ---
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2 Final//EN">
<html>
<head>
  <title>GRASS 6.1.x binary releases for GNU/Linux</title>
</head>
<body>
<h1>How to install the Linux (x86/Intel) binary releases
 of GRASS 6.1.x in gzipped tar format.</h1>
<h2>Use at your own risk.</h2>
You can install and use GRASS 6.1.x in parallel to GRASS 5.0/5.3/5.4.
<h3>Installation:</h3>
<ol>
  <li>get the file <br>
grass-6.1.0-x.distro_version.hw-bin.tar.gz</li>
  <li>get the installation script <br>
grass-6.1.0-x.distro_version.hw-install.sh</li>
</ol>
 from <a href=./>this directory</a>
<h4>where</h4>
<ul>
  <li>x: binary_version</li>
  <li>distro_version: Linux distribution with version</li>
  <li>hw: is the hardware architecture of your platform (e.g. i386)</li>
</ul>
<br>
For installation, run the install script with --help option:<br>
<ul>
  <li>sh grass-6.1.0-x.distro_version.hw-install.sh --help </li>
or <li>./grass-6.1.0-x.distro_version.hw-install.sh --help </li>
</ul>
<br>
Or without help, directly:<br>
<ul>
  <li>sh grass-6.1.0-x.distro_version.hw-install.sh grass61-DD-MM-YYYY-arc-bin.tar.gz <br>
    or</li>
  <li>./grass-6.1.0-x.distro_version.hw-install.sh grass61-DD-MM-YYYY-arc-bin.tar.gz</li>
</ul>
<h3>Libraries</h3>
The following libraries are required:
<ul>
  <li>libpq (e.g. libpq3-7.3.4-2mdk.i586.rpm)</li>
  <li>proj (e.g. proj-4.4.7-1mdk.i586.rpm)</li>
  <li>libproj (e.g. libproj0-4.4.7-1mdk.i586.rpm) </li>
  <li>libgdal(e.g. libgdal0-1.1.9-2mdk.i586.rpm) </li>
</ul>
and, recommended, also:
<ul>
  <li>tcl (e.g. tcl-8.3.3-21mdk.i586.rpm)</li>
  <li>tk (e.g. tk-8.3.3-21mdk.i586.rpm)</li>
  <li>gdal tools (e.g. gdal-1.1.9-2mdk.i586.rpm)</li>
  <li>libfftw (must be fft2, e.g. libfftw2-2.1.5-2mdk.i586.rpm)</li>
  <li>libgrass (e.g. libgrass5-1.0.0-1mdk.src.rpm - but only if inserted in one of above packages as dependency)<br>
  </li>
</ul>
optional:<br>
<ul>
  <li>libgdal0-devel-1.1.9-2mdk.i586.rpm</li>
  <li>libgrass5_0-devel-1.0.0-1mdk.i586.rpm</li>
  <li>libproj0-devel-4.4.7-1mdk.i586.rpm</li>
</ul>
You can find these RPMs at <a href="http://www.rpmfind.net/">www.rpmfind.net</a>
or <a href="http://rpm.pbone.net">rpm.pbone.net</a>
<h3>NOTE:</h3>
In some distributions (e.g. Mandrake) the names of libraries is
slightly different. Check, and if there is no file of the name:<br>
libtk.so.0<br>
libtcl.so.0<br>
libpq.so.2<br>
libgdal.1.1.so<br>
<br>
then you should type:<br>
<br>
su<br>
ln -s /usr/lib/libtk.so /usr/lib/libtk.so.0<br>
ln -s /usr/lib/libtcl.so /usr/lib/libtcl.so.0<br>
ln -s /usr/lib/libpq.so.3 /usr/lib/libpq.so.2<br>
ln -s /usr/lib/libgdal.1.1.so /usr/lib/libgdal.so.1<br>
ldconfig
<p>Instead of (or in addition to) libtk.so and libtcl.so, you might
   have libtk8.4.so and libtcl8.4.so. In this case, type instead:<br>
<br>
ln -s /usr/lib/libtk8.4.so /usr/lib/libtk.so.0<br>
ln -s /usr/lib/libtcl8.4.so /usr/lib/libtcl.so.0<br>
ldconfig<br>
</p>
Get this <a href=README.html>file.</a>
<hr>Please help us and report bugs.<br>
<a href="http://grass.itc.it/bugtracking/bugreport.html">Bug report form</a>
</body>
</html>
More information about the grass-web mailing list
