[GRASSweb-list]markus: web/download addons.inc,1.2,1.3
grass at intevation.de grass at intevation.de
Mon Aug 8 03:57:14 EDT 2005
Author: markus
Update of /grassrepository/web/download
In directory doto:/tmp/cvs-serv25040
Modified Files:
	addons.inc
Log Message:
removed broken links
Index: addons.inc
RCS file: /grassrepository/web/download/addons.inc,v
retrieving revision 1.2
retrieving revision 1.3
diff -u -d -r1.2 -r1.3
--- addons.inc	30 May 2005 11:34:16 -0000	1.2
+++ addons.inc	8 Aug 2005 07:57:12 -0000	1.3
@@ -43,30 +43,6 @@
 </ul>
 <h2>
-GRASS shell extension</h2>
-<ul>
-<li> <a href="http://web.archive.org/web/20041012150607/http://www.acsu.buffalo.edu/~sorokine/complete/">GRASS shell
-completions for parameters and map names</a>: GRASS Complete allows you to
-complete automatically correct arguments for GRASS commands when you press
-'complete' key (usually <TAB>).  It uses a 'complete' feature that is
-available in such UNIX shells as bash, zsh and probably others (A. Sorokine,
-USA)
-</li>
-</ul>
-<h2>
-Misc modules</h2>
-<ul>
-<li>
-<a href="http://www.archive.org/web/*/http://pweb.jps.net/~egm2/">m.cogo</a>:
-The m.cogo utility can translate between bearing-distance descriptions
-and X,Y coordinates. It's a simplistic first stab at providing some COGO
-functionality for GRASS. (Eric G. Miller, U.S.A.)</li>
-</ul>
-<h2>
 Image processing modules</h2>
 <ul>
More information about the grass-web mailing list
