[GRASSweb-list]markus: web/devel i18n.inc,1.4,1.5 roadmap.inc,1.4,1.5
    grass at intevation.de
    Tue Feb  1 03:30:29 EST 2005
Author: markus
Update of /grassrepository/web/devel
In directory doto:/tmp/cvs-serv4421
Modified Files:
	i18n.inc roadmap.inc
Log Message:
version number fixes
Index: i18n.inc
RCS file: /grassrepository/web/devel/i18n.inc,v
retrieving revision 1.4
retrieving revision 1.5
diff -u -d -r1.4 -r1.5
--- i18n.inc	31 Jan 2005 14:51:01 -0000	1.4
+++ i18n.inc	1 Feb 2005 08:30:27 -0000	1.5
@@ -21,7 +21,7 @@
 <p>
 Translation related issues may be discussed there (how to start a new
-translation, how to merge old G5.0 translated messages into G5.7 etc).
+translation, how to merge old G5.0 translated messages into G6.0 etc).
 This is an opportunity for non-programmers to contribute as messages
 can be easily translated. <b>No programming skills required!</b><br>
@@ -35,8 +35,8 @@
 README below):
 <ol>
-<li>get a fresh (!) GRASS 5.7 from <a href=http://freegis.org/grass/grass-cvs.html>CVS</a>
-    (or <a href=../grass57/source/snapshot/>5.7 CVS snapshot</a>)
+<li>get a fresh (!) GRASS 6 from <a href=http://freegis.org/grass/grass-cvs.html>CVS</a>
+    (or <a href=../grass60/source/snapshot/>6.0 CVS snapshot</a>)
 <li>run: '<tt>cd locale</tt>'       to change into the translation directory
 <li>run: '<tt>make pot</tt>'        to create grass*.pot files (containing original messages)
 <li>run: '<tt>make update-po</tt>'  merge new messages into existing *.po files (or create new po files)
@@ -55,7 +55,7 @@
 A multilingual terminal emulator with multi-byte support is <a
 href=http://mlterm.sourceforge.net/>mlterm</a>. <br>
-Using this terminal, GRASS 5.7 is already able to display
+Using this terminal, GRASS 6 is already able to display
 e.g. Japanese fonts in SQL queries (here DBF file):<p>
 <DEFANGED_IMG src=../images/grass57_terminal_jp.png>
Index: roadmap.inc
RCS file: /grassrepository/web/devel/roadmap.inc,v
--- roadmap.inc	28 Jan 2005 17:26:10 -0000	1.4
+++ roadmap.inc	1 Feb 2005 08:30:27 -0000	1.5
@@ -24,7 +24,7 @@
  <li>new revision == bugs have been fixed, go grab it and install it.
  <li>new minor == new features are available, source compatibility _and_ binary
        compatibility for existing applications are garanteed <i>[not fully true for
-       GRASS 5.7 where old vector/sites maps have to be converted by
+       GRASS 5.7/6.x where old vector/sites maps have to be converted by
        v.convert/v.in.sites.]</i>.
  <li>new major == beware! Old (ugly) libraries have been dropped. Database
      compatibility has been broken, you have to migrate your database to the
@@ -88,8 +88,7 @@
     pure PROJ version
 <li>GRASS >= 5.0.0pre4 and <5.3 have Frank Warmerdam's PROJ4 with datum
     functions but they are not used
-<li>GRASS >= 5.3 (so also 5.7) use Frank Warmerdam's PROJ4 with datum
-    functions
+<li>GRASS >= 5.3 and later use Frank Warmerdam's PROJ4 with datum transformation functions
 </ul>
 <P>
More information about the grass-web
