[GRASSweb-list]markus: web/faq cvs_howto.html,1.7,1.8
grass at intevation.de grass at intevation.de
Fri Feb 4 10:42:53 EST 2005
Author: markus
Update of /grassrepository/web/faq
In directory doto:/tmp/cvs-serv31217/faq
Modified Files:
	cvs_howto.html
Log Message:
updates for beta2
Index: cvs_howto.html
RCS file: /grassrepository/web/faq/cvs_howto.html,v
retrieving revision 1.7
retrieving revision 1.8
diff -u -d -r1.7 -r1.8
--- cvs_howto.html	19 Dec 2004 20:20:47 -0000	1.7
+++ cvs_howto.html	4 Feb 2005 15:42:51 -0000	1.8
@@ -16,18 +16,19 @@
 (and maybe phone costs).]
 <p>To access the latest GRASS
 source code from our <a href="../devel/cvs.php">CVS repository</a>, do
-following (this assumes you want the latest source code to GRASS 5.3-cvs;  see
-the page on <a href="../devel/cvstags.php">CVS tags</a> for more information on obtaining source for other versions:
+following (this assumes you want the latest source code to GRASS-cvs;  see
+the page on <a href="../devel/cvstags.php">CVS tags</a> for more information
+on obtaining source for other versions:
 <ol>
 <li>
 To reduce download time, get
-the weekly <a href="../grass57/source/snapshot/">CVS snapshot</a>. It contains
+the weekly <a href="../grass60/source/snapshot/">CVS snapshot</a>. It contains
 the entire sources including the CVS subdirectories which you need to synchronize
 this package with CVS.</li>
 <li>
 Extract this package as described
-<a href="../grass57/source/README.html">here</a>
+<a href="../grass60/source/README.html">here</a>
 (it is the README from the source directory). The full sources of the GRASS
 Project require about 100 MB.</li>
@@ -72,7 +73,7 @@
 </ol>
 <h3>Updating the GRASS code later on:</h3>
-<p>GRASS 5.3-CVS: The snapshot has to be transmitted
+<p>GRASS 6-CVS: The snapshot has to be transmitted
 once only. For future updates simply run the following command within the main GRASS
 source directory:
 <br><tt>&nbsp;&nbsp; cvs up
@@ -81,10 +82,8 @@
 code again. You can also just update a subdirectory: cd to this directory
 and use above command.
 <P>
-<P>GRASS 5.7: you have to keep in sync both 5.3-CVS and 5.7-CVS. Please refer
-to the INSTALL file within the 5.7 source code for details.
-<p>Enjoy ongoing GRASS 5 development!
+<p>Enjoy ongoing GRASS development!
 <hr><a href="index.html">Go back to GRASS GIS FAQ...
 <hr></a><i>Last Modified: $Date$</i>
 <address>
More information about the grass-web mailing list
