[GRASSweb-list]markus: web/devel cvs.inc,1.4,1.5 cvstags.inc,1.3,1.4 devel.inc,1.8,1.9 i18n.inc,1.6,1.7 i18n_stats.inc,1.3,1.4
grass at intevation.de grass at intevation.de
Tue Feb 8 16:51:27 EST 2005
Author: markus
Update of /grassrepository/web/devel
In directory doto:/tmp/cvs-serv10982/devel
Modified Files:
	cvs.inc cvstags.inc devel.inc i18n.inc i18n_stats.inc
Log Message:
grass51 -> grass6
Index: cvs.inc
RCS file: /grassrepository/web/devel/cvs.inc,v
retrieving revision 1.4
retrieving revision 1.5
diff -u -d -r1.4 -r1.5
--- cvs.inc	2 Feb 2005 14:34:22 -0000	1.4
+++ cvs.inc	8 Feb 2005 21:51:25 -0000	1.5
@@ -86,8 +86,8 @@
   <tt>export CVSROOT=:pserver:grass-guest at intevation.de:/home/grass/grassrepository</tt>
   <p>
    Then do a "cvs login" and type "grass" when your are asked for password.<br>
-   Now you can checkout the tree using the command (grass51 contains GRASS 6!)<br>
-   <tt>cvs -z3 co grass51</tt>
+   Now you can checkout the tree using the command <br>
+   <tt>cvs -z3 co grass6</tt>
 <P>
 See more detailed <a href="http://freegis.org/grass/">GRASS-CVS access instructions</a> to
 access the anomymous CVS. Even more detailed instructions: <a
Index: cvstags.inc
RCS file: /grassrepository/web/devel/cvstags.inc,v
retrieving revision 1.3
diff -u -d -r1.3 -r1.4
--- cvstags.inc	4 Feb 2005 15:42:51 -0000	1.3
+++ cvstags.inc	8 Feb 2005 21:51:25 -0000	1.4
@@ -31,7 +31,7 @@
 <ul>
 <li>To check out the latest <b>unstable</b> 6 code into a fresh directory, enter:
 <p>
-    <tt>cvs -z3 checkout grass51</tt>
+    <tt>cvs -z3 checkout grass6</tt>
 <p>
 </ul>
Index: devel.inc
RCS file: /grassrepository/web/devel/devel.inc,v
retrieving revision 1.8
retrieving revision 1.9
diff -u -d -r1.8 -r1.9
--- devel.inc	4 Feb 2005 15:42:51 -0000	1.8
+++ devel.inc	8 Feb 2005 21:51:25 -0000	1.9
@@ -147,7 +147,7 @@
   <li>GRASS 6.0 Programmer's Manual <a href=../grass60/manuals/>PDF and HTML</a>
   <li> <a href=../demos/r.example.tar.gz>r.example: example C code for GRASS
      raster programming</a>
-  <li> <a href="http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass51/doc/vector/v.example.c?rev=HEAD&content-type=text/x-csrc">v.example: example C code for GRASS 6
+  <li> <a href="http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass6/doc/vector/v.example.c?rev=HEAD&content-type=text/x-csrc">v.example: example C code for GRASS 6
      vector programming</a>
 </ul>
 </ul>
Index: i18n.inc
RCS file: /grassrepository/web/devel/i18n.inc,v
retrieving revision 1.6
retrieving revision 1.7
diff -u -d -r1.6 -r1.7
--- i18n.inc	2 Feb 2005 13:15:06 -0000	1.6
+++ i18n.inc	8 Feb 2005 21:51:25 -0000	1.7
@@ -46,7 +46,7 @@
 Please, click here to see details (find the README in the locale/ directory as well):
 <br>
-&nbsp;&nbsp;&nbsp;&nbsp;Translation <a href="http://freegis.org/cgi-bin/viewcvs.cgi/grass51/locale/README?rev=HEAD&content-type=text/vnd.viewcvs-markup">README</a>
+&nbsp;&nbsp;&nbsp;&nbsp;Translation <a href="http://freegis.org/cgi-bin/viewcvs.cgi/grass6/locale/README?rev=HEAD&content-type=text/vnd.viewcvs-markup">README</a>
 <P>
 Once the procedure got stabilized, we'll extend this web page.
Index: i18n_stats.inc
RCS file: /grassrepository/web/devel/i18n_stats.inc,v
--- i18n_stats.inc	2 Feb 2005 13:14:24 -0000	1.3
+++ i18n_stats.inc	8 Feb 2005 21:51:25 -0000	1.4
@@ -59,7 +59,7 @@
 <h3>Download of existing .po files</h3>
-<a href="http://freegis.org/cgi-bin/viewcvs.cgi/grass51/locale/po/">Download current .po files</a>
+<a href="http://freegis.org/cgi-bin/viewcvs.cgi/grass6/locale/po/">Download current .po files</a>
 from CVS (useful if you want to partecipate without compiling GRASS). Please
 announce your efforts on the 'GRASS translations' mailing list (see above) to
 avoid that work is doubled. To start a new language, you can simply rewrite an
More information about the grass-web mailing list
