[GRASSweb-list]markus: web/grass57 index.html,1.80,1.81
grass at intevation.de
Fri Jan 14 10:08:58 EST 2005
Author: markus
Update of /grassrepository/web/grass57
In directory doto:/tmp/cvs-serv27214
Modified Files:
Log Message:
removed outdated stuff
Index: index.html
RCS file: /grassrepository/web/grass57/index.html,v
retrieving revision 1.80
retrieving revision 1.81
diff -u -d -r1.80 -r1.81
--- index.html 13 Jan 2005 14:00:44 -0000 1.80
+++ index.html 14 Jan 2005 15:08:56 -0000 1.81
@@ -119,13 +119,6 @@
</ul>
</ul>
-The 5.7-CVS code (still) requires the experimental tree of GRASS 5.3 code
-(preferably from the same hour) to compile. The 5.3 code will be partly merged
-into the 5.7 directory structure during compilation. From time to time more
-code will be migrated into 5.7.
-<P>
-The officially released source code packages contain <b>all required code</b>.
<h2>Large File Support</h2>
GRASS 5.7 supports reading and writing large files (> 2GB)
if it is possible in your operating system. If you compile with
More information about the grass-web
