[GRASSweb-list]markus: web/grass60 main.inc,1.5,1.6
grass at intevation.de
Thu Jan 20 09:24:17 EST 2005
Author: markus
Update of /grassrepository/web/grass60
In directory doto:/tmp/cvs-serv26370/grass60
Modified Files:
main.inc
Log Message:
LFS note
Index: main.inc
RCS file: /grassrepository/web/grass60/main.inc,v
retrieving revision 1.5
retrieving revision 1.6
diff -u -d -r1.5 -r1.6
--- main.inc 20 Jan 2005 12:58:00 -0000 1.5
+++ main.inc 20 Jan 2005 14:24:15 -0000 1.6
@@ -118,7 +118,9 @@
<li> GRASS 6.0 supports reading and writing large files (> 2GB)
if it is possible in your operating system. If you compile with
<tt>-D_FILE_OFFSET_BITS=64</tt>, you should be able to have raster maps
- which are larger than 2Gb</li>
+ which are larger than 2Gb. Note that the support currently only applies
+ to the core raster I/O code. Individual programs may or may not work
+ with large files - please report.</li>
</ul>
</ul>
More information about the grass-web
