[GRASSweb-list]markus: web/bugtracking bugreport.html,1.33,1.34
grass at intevation.de
Tue Jul 12 03:08:59 EDT 2005
Author: markus
Update of /grassrepository/web/bugtracking
In directory doto:/tmp/cvs-serv10101
Modified Files:
bugreport.html
Log Message:
5.x -> 6.x
Index: bugreport.html
RCS file: /grassrepository/web/bugtracking/bugreport.html,v
retrieving revision 1.33
retrieving revision 1.34
diff -u -d -r1.33 -r1.34
--- bugreport.html 2 Mar 2005 21:12:06 -0000 1.33
+++ bugreport.html 12 Jul 2005 07:08:57 -0000 1.34
@@ -21,7 +21,7 @@
<p>
<ul>
<li> Only report if using at least the current stable release version
-(GRASS 5.4.0 was released 5 November 2004), but preferably 6.0 or later.
+(GRASS 6.0.0 was released 10 March 2005) or later.
If you use an older version, please consider <a href=../download/index.php>upgrading</a>.
<li> Before reporting a bug, please check that it is currently unkown:
@@ -59,7 +59,7 @@
<td>
<select name="area">
<option value="grass5.4">bug in GRASS 5.4
- <option value="grass6">bug in GRASS 5.7/6.0
+ <option value="grass6">bug in GRASS 6.0/6.1
<option value="wish6">wish for GRASS 6.1
</select>
</td>
More information about the grass-web
