[GRASSweb-list]william: web/platforms/macgrass grassinstall.php,1.3,1.4 libjpeg.php,1.3,1.4 libtool135update.zip,1.3,1.4
grass at intevation.de
Wed Jul 20 20:03:11 EDT 2005
Author: william
Update of /grassrepository/web/platforms/macgrass
In directory doto:/tmp/cvs-serv15868
Modified Files:
grassinstall.php libjpeg.php libtool135update.zip
Log Message:
more fine tuning macgrass, and last corrupt zip removed (hopefully)
Index: grassinstall.php
RCS file: /grassrepository/web/platforms/macgrass/grassinstall.php,v
retrieving revision 1.3
retrieving revision 1.4
diff -u -d -r1.3 -r1.4
--- grassinstall.php 20 Jul 2005 04:10:17 -0000 1.3
+++ grassinstall.php 21 Jul 2005 00:03:09 -0000 1.4
@@ -15,11 +15,12 @@
<hr width="100%" noshade="noshade" size="3">
<h1>GRASS GIS on Mac OS X</h1>
<h1 align="Center">Installation Main</h1>
-<p align="Center"><i>Last change: 2005/7/16</i></p>
+<p align="Center"><i>Last change: 2005/7/16</i><br>
+William Kyngesburye <kyngchaos-at-kyngchaos-dot-com></p>
</center>
-<p><b>NOTE:</b> These instructions are for GRASS v6.0.0, but should work with little or no change for GRASS CVS.</p>
+<p><b>NOTE:</b> These instructions are for GRASS v6.0.0, but should work with little or no change for GRASS CVS. And, read everything here and pay attention.</p>
<h3>Introduction</h3>
@@ -27,7 +28,7 @@
<p>So, we're left to fend for ourselves. Or to let others do it and distribute <a href="/download/index.php">binaries</a>. But these pages are for the do-it-yourselfers.</p>
-<p>We mostly have to start from scratch, and use what is provided by Apple when we can. There are a couple options: do it all yourself, or start with a base of one of the few package managers (Fink and Darwinports). These pages show you how to start from scratch, tho they could be easily adapted to using stuff from Fink or Darwinports. Be warned that they can cause headaches that I won't get into, and you are on your own figuring it out.</p>
+<p>We mostly have to start from scratch, and use what is provided by Apple when we can. There are a couple options: do it all yourself, or start with a base of one of the few package managers (Fink and Darwinports) or some other library base (Graphics Libs, GIS Libs). These pages show you how to start from scratch, tho they could be easily adapted to using stuff from Fink or Darwinports. Be warned that they can cause headaches that I won't get into, and you are on your own figuring it out.</p>
<p>These instructions assume very little command line knowledge, and try to be explicit and detailed. Be warned, there is a bit of patching to do for a few items. Some, unchanging, items use patch files that you must download, it's easier and reduces error. But most others will be patching instructions, so it's easier to apply it to future versions of the library.</p>
Index: libjpeg.php
RCS file: /grassrepository/web/platforms/macgrass/libjpeg.php,v
--- libjpeg.php 20 Jul 2005 04:07:39 -0000 1.3
+++ libjpeg.php 21 Jul 2005 00:03:09 -0000 1.4
@@ -27,7 +27,7 @@
<blockquote><code>$ cd <i>path_to_folder_containing_libjpeg_source_tar_gz</i><br>
$ tar -zxf jpegsrc.v6b.tar.gz</code></blockquote>
-<p>Then, replace ltconfig and ltmain.sh with these <a href="libtool135update.zip">patched</a> versions. They contain a couple Mac OS X patches to the version of libtool in the kpeg source. Also, download this <a href="jpegpatch.zip">patch</a> for the makefile and unzip it into the source folder.</p>
+<p>Then, replace ltconfig and ltmain.sh with these <a href="libtool135update.zip">patched</a> versions. They contain a couple Mac OS X patches to the version of libtool in the jpeg source. Also, download this <a href="jpegpatch.zip">patch</a> for the makefile and unzip it into the source folder.</p>
<p>Then continue:</p>
Index: libtool135update.zip
RCS file: /grassrepository/web/platforms/macgrass/libtool135update.zip,v
Binary files /tmp/cvs8gh6Ki and /tmp/cvsodIDtr differ
More information about the grass-web
