[GRASSweb-list]martin: web/newsletter GRASSNews_vol3_erratum.txt,NONE,1.1
grass at intevation.de
Mon Jun 27 04:24:17 EDT 2005
Author: martin
Update of /grassrepository/web/newsletter
In directory doto:/tmp/cvs-serv15997
Added Files:
Log Message:
erratum of GRASS-News 3 as txt
--- NEW FILE: GRASSNews_vol3_erratum.txt ---
Erratum of GRASS-News vol. 3 (June 2005)
Interfacing GRASS 6 and R
(R. Bivand)
Problem: select CRAN mirror without X11 running
- development files for gdal are necessary (e.g. for a Debian box,
apt-get install libgdal-dev)
- in case you get the error: --- Please select a CRAN mirror for use in this session ---
(when a graphic monitor is not available for whathever reason, e.g. in case of remote installations)
-- add the address of a CRAN mirror to your install command, e. g. install.packages(c("sp","rgdal"), dependencies=TRUE,
repos="http://microarrays.unife.it/CRAN/")
-- alternatively, one could set the search of cran mirror to non-graphic, by
typing: chooseCRANmirror(graphics=FALSE) before the install command.
(added June 2005)
________________
More information about the grass-web
