[GRASSweb-list]markus: web/grass60/binary/linux/snapshot README.html,1.1,1.2
grass at intevation.de
Sat Mar 12 12:57:24 EST 2005
Author: markus
Update of /grassrepository/web/grass60/binary/linux/snapshot
In directory doto:/tmp/cvs-serv24405
Modified Files:
README.html
Log Message:
6.0 -> 6.1
Index: README.html
RCS file: /grassrepository/web/grass60/binary/linux/snapshot/README.html,v
retrieving revision 1.1
retrieving revision 1.2
diff -u -d -r1.1 -r1.2
--- README.html 14 Jan 2005 18:11:01 -0000 1.1
+++ README.html 12 Mar 2005 17:57:22 -0000 1.2
@@ -3,23 +3,23 @@
<HEAD>
<DEFANGED_meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<DEFANGED_meta name="Author" content="GRASS Development Team/MN">
- <TITLE>GRASS 6.0.CVS experimental GNU/Linux binaries</TITLE>
+ <TITLE>GRASS 6.1.cvs experimental GNU/Linux binaries</TITLE>
</HEAD>
<BODY>
-<H1>GRASS 6.0.CVS experimental GNU/Linux binaries</H1>
+<H1>GRASS 6.1.cvs experimental GNU/Linux binaries</H1>
<h2>How to install the Linux (x86/Intel) binary code for
-GRASS 6.0.x EXPERIMENTAL in gzipped tar format.</h2>
+GRASS 6.1.cvs EXPERIMENTAL in gzipped tar format.</h2>
<b>Note: Occasionally, weekly snapshots may not work properly; in
case, please revert to a previous version.</b>
<P>
-You can install and use GRASS 6.0 in parallel to GRASS 5.0/5.3.
+You can install and use GRASS 6 in parallel to GRASS 5.0/5.4.
<h3>Installation:</h3>
<ol>
- <li>get the file <br>grass-6.0.cvs-ARCH-DD_MM_YYYY.tar.gz</li>
- <li>get the installation script <br> grass-6.0.cvs-ARCH-DD_MM_YYYY-install.sh</li>
+ <li>get the file <br>grass-6.1.cvs-ARCH-DD_MM_YYYY.tar.gz</li>
+ <li>get the installation script <br> grass-6.1.cvs-ARCH-DD_MM_YYYY-install.sh</li>
</ol>
<h4>where</h4>
<ul>
@@ -30,16 +30,16 @@
For installation, run the install script with --help option:<br>
<ul>
- <li>sh grass-6.0.cvs-ARCH-DD_MM_YYYY-install.sh --help </li>
+ <li>sh grass-6.1.cvs-ARCH-DD_MM_YYYY-install.sh --help </li>
or
- <li>./grass-6.0.cvs-ARCH-DD_MM_YYYY-install.sh --help </li>
+ <li>./grass-6.1.cvs-ARCH-DD_MM_YYYY-install.sh --help </li>
</ul><br>
Or without help, directly:<br>
<ul>
- <li>sh grass-6.0.cvs-ARCH-DD_MM_YYYY-install.sh grass60-DD-MM-YYYY-arc-bin.tar.gz</li>
+ <li>sh grass-6.1.cvs-ARCH-DD_MM_YYYY-install.sh grass60-DD-MM-YYYY-arc-bin.tar.gz</li>
or
- <li>./grass-6.0.cvs-ARCH-DD_MM_YYYY-install.sh grass60-DD-MM-YYYY-arc-bin.tar.gz</li>
+ <li>./grass-6.1.cvs-ARCH-DD_MM_YYYY-install.sh grass60-DD-MM-YYYY-arc-bin.tar.gz</li>
</ul>
<h3>Libraries</h3>
The following libraries and programs are required:
@@ -89,16 +89,16 @@
Also, it is necessary to tell the system the location of grass libraries:<br><br>
vi /etc/ld.so.conf<br>
Add grass path, e.g.:<br>
- /usr/local/grass-6.0.cvs-i686-pc-linux-gnu-14_01_2005/lib<br>
+ /usr/local/grass-6.1.cvs-i686-pc-linux-gnu-14_01_2005/lib<br>
then<br>
ldconfig<br>
<h1>How to uninstall</h1>
-sh /usr/local/bin/grass60uninstall.sh<br>
+sh /usr/local/bin/grass61uninstall.sh<br>
If it's not there, then:<br>
-rm -rf /usr/local/bin/grass60<br>
-rm -rf /usr/local/bin/grass60-DD-MM-YYYY<br>
-rm -rf /usr/local/grass60-DD-MM-YYYY<br>
+rm -rf /usr/local/bin/grass61<br>
+rm -rf /usr/local/bin/grass61-DD-MM-YYYY<br>
+rm -rf /usr/local/grass61-DD-MM-YYYY<br>
<P>
<hr>
This snapshot was configured as follows:
More information about the grass-web
