[GRASSweb-list]r.le.rename for GRASS 6.0
rsadler at cyllene.uwa.edu.au rsadler at cyllene.uwa.edu.au
Mon Oct 3 02:52:35 EDT 2005
Hi All,
I want to use the GRASS 6.0 application that I have developed on a
computing cluster, which is now possible with the GRASS 6.0 multi-session
capability (whereas GRASS 5< did not have this capability).
The application involves a large number of simulations of a spatial
process from which metrics are calculated using the r.le program.
However, when I run r.le.patch (for example) under multi-sessions you get
a simultaneous overwriting of the r.le.out files, thus "stuffing up" the
data. Under GRASS 5 this was solved by the r.le.rename function. However,
it does not seem that r.le.rename exists for GRASS 6.
Using the "out" option on r.le.patch does not provide the output I am
interested in - I am looking for whole map summary statistics (although I
could construct one from the other).
Please advise.
Regards
Rohan Sadler
PhD Candidate
The University of Western Australia
School of Mathematics and Statistics and School of Plant Biology
More information about the grass-web mailing list
