[GRASSweb-list]cvs howto out of date
Scott Mitchell
smitch at mac.com
Tue Oct 25 19:52:19 EDT 2005
Are you sure about that?
The directions there don't ask you to use the checkout command at all -
they suggest you download the latest CVS snapshot, and then cd into
that directory and use cvs up -dP to update that snapshot from the
repository. I've just checked, and the snapshot that it downloads is
indeed version 6, so when you then cd into the directory and ask for an
update, it should get it from the version 6 repository.
I wonder - did you already have an existing source tree on your system,
and you did a cd into THAT directory and issue the cvs up command?
Because if you did, it will update to whatever tree/branch (!) was used
to originally check it out.
If you followed the full set of steps, I think it should work as
written. If you were hoping to update from 5.5 to 6, then you need to
check out the new tree, but that's not what the instructions are
written for.
I've just tested the instructions step by step, and end up with 6.0.2cvs
Cheers,
Scott Mitchell
On 25 Oct 2005, at 19:21, Shaun Walbridge wrote:
> hi weblist,
> On the page:
> http://grass.itc.it/faq/cvs_howto.html
> step 5 should probably be changed to:
> cvs -z3 co grass6
> to work properly. I folloed the directions as given, and
> unfortunately I inadvertently checked out & built GRASS 5.5.
> best wishes,
> Shaun Walbridge
> weblist mailing list
> weblist at grass.itc.it
> http://grass.itc.it/mailman/listinfo/weblist
Scott W. Mitchell Scott_Mitchell at carleton.ca
Department of Geography and Environmental Studies
Carleton University, B349 Loeb Building
Ottawa, ON Canada K1S 5B6
+1-613-520-2600 ext 2695
More information about the grass-web
