[GRASSweb-list]Help with turning DIGEST delivery mode off
Markus Neteler neteler at itc.it
Fri Sep 2 07:33:39 EDT 2005
On Thu, Sep 01, 2005 at 08:54:11AM -0400, Scott Mitchell wrote:
> That depends which mailing list you're talking about.  Looks like
> you're not subscribed to this list (GRASSweb-list), so you must mean
> a different list.
> If you are referring to the International GRASS User's list
> ("GRASSlist") -- yes, I see that there are instructions for setting
> it up to switch TO digest mode but not back.  I THINK the step you
> need is to do this:
> send an email message to the address listproc at baylor.edu with only
> the following in the message body:
> set grasslist at baylor.edu MAIL
> Let us know if that does the trick for you (IF that's the list we're
> talking about), and if all goes well I'll add the detail to the web
> instructions.
it's explained here:
 http://grass.itc.it/community/support.php#int_list
 Maybe not yet clean enough?
Markus
More information about the grass-web mailing list
