[GRASSweb-list]help to install and run Grass 6.0 under Windows XP
Markus Neteler
neteler at itc.it
Fri Sep 30 09:36:13 EDT 2005
On Thu, Sep 15, 2005 at 08:33:11AM -0700, Paulo Froes wrote:
> Grass team,
> Hi!
> I am having a hard time to have Grass 6.0 running in my machine (Windows XP). To start with, the database path shown in the opening screen does not seem to be correct, the "Browse" button at the right of the DATABASE field does not seem to help much in that regard, etc. It is a bit frustrating as we would appreciate to be able to at least to learn and work a bit with GRASS and its reported functionality
> Thanks in advance for any possible help
Paulo,
please consider to read some tutorial:
http://grass.itc.it/gdp/tutorials.php
The Spearfish6 sample database will be required to the installed (get from
download section, sample data).
Regards
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
More information about the grass-web
