[GRASSweb-list]Enquiry about Grass Installation
Markus Neteler neteler at itc.it
Fri Sep 30 09:56:46 EDT 2005
On Tue, Sep 13, 2005 at 01:23:13PM -0000, Prakash Kumar wrote:
> Hi,
> I am  in knowing about the software Grass. While installing by downloading from web I am asked to select the EPSG codes . Since I am working with 'No Datum, Lat-long; Degrees -180 to +180' I am unable to findout the same from codes given by you in a tabular form.
> Since I am interested to work for the entire country of India, I would like to know which EPSG code would be the best fitted for the entire country.
> I would come back with more questions.
> Thanks,
> Best Wishes,
> Prakash
The EPSG code of Lat-long is: 4326.
Using "no datum" is not recommended, usually the WGS84 datum is used.
Regards
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
More information about the grass-web mailing list
