[GRASSweb-list]markus: web/grass61/source compilation_debian.txt,NONE,1.1
grass at intevation.de
Sat Apr 1 14:59:26 EST 2006
Author: markus
Update of /grassrepository/web/grass61/source
In directory doto:/tmp/cvs-serv19972
Added Files:
Log Message:
added
--- NEW FILE: compilation_debian.txt ---
How to make GRASS debian packages from CVS
Download and untar latest grass snapshot, then:
mv grass-6.1.cvs_src_snapshot_2005_08_06 grass-6.1.0
then update it from CVS:
export CVSROOT=:pserver:grass-guest at intevation.de:/home/grass/grassrepository
(this must be done just the first time)
cvs login
passwd: grass
cd grass-6.1.0
cvs up -dP
or (quieter, shows only the changes):
cvs -q up -dP
In case of a previous error during package building or compilation, you'll
have some files marked with "M", or conflicting; remove them before going
further, then once more
cvs -q up -dP
Then either:
su
dpkg-buildpackage
or, as a normal user:
fakeroot dpkg-buildpackage
A number of -dev packages must be installed for this to work; if they're not,
dpkg-buildpackage gives an understandable error message. Please install them
before proceeding.
cd ..
dpkg -i grass-doc_6.1.0-1_all.deb grass_6.1.0-1_i386.deb libgrass_6.1.0-1_i386.deb
More information about the grass-web
