[GRASSweb-list] markus: web/bugtracking bugreport.html,1.41,1.42
grass at intevation.de grass at intevation.de
Fri Aug 4 12:11:07 EDT 2006
Author: markus
Update of /grassrepository/web/bugtracking
In directory doto:/tmp/cvs-serv1475
Modified Files:
	bugreport.html
Log Message:
GRASS 6 first
Index: bugreport.html
RCS file: /grassrepository/web/bugtracking/bugreport.html,v
retrieving revision 1.41
retrieving revision 1.42
diff -u -d -r1.41 -r1.42
--- bugreport.html	4 Aug 2006 16:04:13 -0000	1.41
+++ bugreport.html	4 Aug 2006 16:11:05 -0000	1.42
@@ -24,7 +24,7 @@
 <p>
 <ul>
 <li> Only report if using at least the current stable release version
-(GRASS 6.0.1 was released  22 August 2005) or later.
+(GRASS 6.0.2 was released  22 Feb 2006) or later.
 If you use an older version, please consider <a href=../download/index.php>upgrading</a>.
 <li> Before reporting a bug, please check that it is currently unkown:
@@ -64,11 +64,11 @@
 <th align=left>Type of report: </th>
 <td>
 	<select name="area">
-	<option value="grass5.4">bug in GRASS 5.4
 	<option value="grass6">bug in GRASS 6.0/6.1
 	<option value="wish6">wish for GRASS 6.1
-        <option value="doc-grass6">docs bug in GRASS 6
-        <option value="doc-wish-grass6">docs wish for GRASS 6
+	<option value="doc-grass6">docs bug in GRASS 6
+	<option value="doc-wish-grass6">docs wish for GRASS 6
+	<option value="grass5.4">bug in GRASS 5.4
 	</select>
 </td>
 </tr>
More information about the grass-web mailing list
