[GRASSweb-list] markus: web/devel devel.inc,1.37,1.38
grass at intevation.de
Tue Aug 29 10:28:36 EDT 2006
Author: markus
Update of /grassrepository/web/devel
In directory doto:/tmp/cvs-serv6640/devel
Modified Files:
devel.inc
Log Message:
link to new progman
Index: devel.inc
RCS file: /grassrepository/web/devel/devel.inc,v
retrieving revision 1.37
retrieving revision 1.38
diff -u -d -r1.37 -r1.38
--- devel.inc 2 Aug 2006 20:22:55 -0000 1.37
+++ devel.inc 29 Aug 2006 14:28:34 -0000 1.38
@@ -128,8 +128,8 @@
<ul>
<li>GRASS <a href=../grass61/manuals/>6 Programmer's Manual</a>
(PDF and packaged HTM; complete, updated weekly every Saturday)
- <li> GRASS <a href="http://mpa.itc.it/markus/grass61progman/">6 Programmer's Manual</a> (HTML, updated regularly, generated with 'make htmldocs-single')
- <li> GRASS <a href="http://mpa.itc.it/markus/grass61progman/swig/">SWIG interface</a> (HTML, updated regularly)
+ <li> GRASS <a href="http://mpa.itc.it/markus/grass63progman/">6 Programmer's Manual</a> (HTML, updated regularly, generated with 'make htmldocs-single')
+ <li> GRASS <a href="http://mpa.itc.it/markus/grass63progman/swig/">SWIG interface</a> (HTML, updated regularly)
<li> <a href="../searchgrass.php">Search GRASS 6 Programmer's Manual</a>
<li> <a href="http://freegis.org/cgi-bin/viewcvs.cgi/grass6/doc/raster/">r.example</a>: example C code for GRASS raster programming
<li> <a href="http://freegis.org/cgi-bin/viewcvs.cgi/grass6/doc/vector/v.example/">v.example</a>: example C code for GRASS 6 vector programming
More information about the grass-web
