[GRASSweb-list]markus: web/devel roadmap.inc,1.7,1.8 roadmap.php,1.3,1.4
grass at intevation.de grass at intevation.de
Mon Feb 27 18:23:10 EST 2006
Author: markus
Update of /grassrepository/web/devel
In directory doto:/tmp/cvs-serv16945
Modified Files:
	roadmap.inc roadmap.php
Log Message:
some items added
Index: roadmap.inc
RCS file: /grassrepository/web/devel/roadmap.inc,v
retrieving revision 1.7
retrieving revision 1.8
diff -u -d -r1.7 -r1.8
--- roadmap.inc	3 Jul 2005 19:17:17 -0000	1.7
+++ roadmap.inc	27 Feb 2006 23:23:08 -0000	1.8
@@ -176,14 +176,13 @@
       <ul>
         <li>new 2D/3D vector engine (almost done)</li>
 	<li>eliminate sites by migrating to vector points[2]</li>
-        <li>new vector network library (done, needs fixes)</li>
-        <li>DBMS support (partially done, PG driver needs rewrite)</li>
+        <li>new vector network library (done, needs fixes in cache)</li>
+        <li>DBMS support (done)</li>
         <li>migration of old vector modules (almost done)</li>
-        <li>keep sites format [1] ("done")</li>
+        <li>keep but discourage sites format [1] ("done")</li>
         <li>better integrate G3D voxel (partially done)
-        <li>new Makefile system (almost done)</li>
-        <li>shared libraries (done), static libraries also supported</li>
-        <li>initial cleanup libs (TODO)</li>
+        <li>new Makefile system (done)</li>
+        <li>shared libraries (done), static libraries also supported</li>
         <li>initial code inline docs (doxygen based, partially done)</li>
       </ul>
 [1] to keep the sites modules for a while seems to be necessary as we
@@ -209,14 +208,18 @@
       </ul>
       </td>
       <td
- style="vertical-align: top; background-color: rgb(255, 255, 204);">6.1.x
-...<br>
+ style="vertical-align: top; background-color: rgb(255, 255, 204);">6.1.x...<br>
        <ul>
-        <li>improve raster format (library)</li>
+        <li>improve/rewrite raster data library (TODO, maybe GRASS 7?)</li>
         <li>change raster maps directory layout (store all map related files into a single directory)
-            MAPSET/TYPE/MAPNAME/FILES [3]</li>
+            MAPSET/TYPE/MAPNAME/FILES [3] (TODO)</li>
+        <li>rename raster functions G_*() to Rast_*() (TODO)</li>
         <li>improve image processing</li>
+        <li>cleanup libs/modules from clones (ongoing)</li>
+        <li>implement SQL based time series support for raster maps (TODO)</li>
+        <li>implement topology-free points support for LIDAR (ongoing)</li>
+        <li>rewrite display drivers (ongoing)</li>
        </ul>
       [3] done for the new vector format, advantage to simplify maintenance and backups.
       </td>
Index: roadmap.php
RCS file: /grassrepository/web/devel/roadmap.php,v
retrieving revision 1.3
retrieving revision 1.4
diff -u -d -r1.3 -r1.4
--- roadmap.php	15 Nov 2005 13:13:02 -0000	1.3
+++ roadmap.php	27 Feb 2006 23:23:08 -0000	1.4
@@ -81,7 +81,7 @@
 </table>
 <hr>
-   <div align="right">&copy; 2004 GRASS Development Team<br>
+   <div align="right">&copy; 2004-2006 GRASS Development Team<br>
    <a href="../impressum.html">Imprint</a> |
    <a href="../contact.php">Comments</a> about this page<br>
    </div>
More information about the grass-web mailing list
