[GRASSweb-list]markus: web/grass60 main.inc,1.21,1.22
grass at intevation.de grass at intevation.de
Thu Jan 12 11:20:18 EST 2006
Author: markus
Update of /grassrepository/web/grass60
In directory doto:/tmp/cvs-serv15635
Modified Files:
	main.inc
Log Message:
LFS is not really realiable
Index: main.inc
RCS file: /grassrepository/web/grass60/main.inc,v
retrieving revision 1.21
retrieving revision 1.22
diff -u -d -r1.21 -r1.22
--- main.inc	6 Jan 2006 22:58:57 -0000	1.21
+++ main.inc	12 Jan 2006 16:20:16 -0000	1.22
@@ -145,8 +145,11 @@
 </ul>
 <li> Large File Support for raster maps</li>
+<b>Experimental!</b>
 <ul>
-  <li> GRASS 6.0 supports reading and writing large files (> 2GB)
+  <li> GRASS 6.0 experimentally supports reading and writing large files (> 2GB, LFS support)
    if it is possible in your operating system. If you compile with
    <tt>-D_FILE_OFFSET_BITS=64</tt>, you should be able to have raster maps
    which are larger than 2Gb. Note that the support currently only applies
More information about the grass-web mailing list
