[GRASSweb-list]stephan: web/devel iso_639-1.txt,NONE,1.1 i18n_stats.inc,1.13,1.14
grass at intevation.de
Wed Jan 18 03:50:01 EST 2006
Author: stephan
Update of /grassrepository/web/devel
In directory doto:/tmp/cvs-serv23281
Modified Files:
i18n_stats.inc
Added Files:
iso_639-1.txt
Log Message:
+ merged iso-names into statistics table.
--- NEW FILE: iso_639-1.txt ---
(This appears to be a binary file; contents omitted.)
Index: i18n_stats.inc
RCS file: /grassrepository/web/devel/i18n_stats.inc,v
retrieving revision 1.13
retrieving revision 1.14
diff -u -d -r1.13 -r1.14
--- i18n_stats.inc 14 Dec 2005 19:46:10 -0000 1.13
+++ i18n_stats.inc 18 Jan 2006 08:49:58 -0000 1.14
@@ -9,11 +9,26 @@
// einlesen der Datei
$array = file($file);
+ // read in the iso-table
+ $array_iso = file("./iso_639-1.txt");
+ // extract the relevant columns
+ $array_iso2 = array(); /*iso-kuerzel*/
+ $array_iso3 = array(); /*Klartext-name*/
+ foreach($array_iso as $id => $value) {
+ $array_iso1 = explode("\"", $value);
+ // neue arrays schreiben
+ array_push($array_iso2, $array_iso1[7]);
+ array_push($array_iso3, $array_iso1[1]);
+ foreach($array_iso2 as $key => $value) {
+ $new[$array_iso2[$key]] .= $array_iso3[$key];
<P>
<table border="1" width="50%">
<tr>
- <th>PO-Files</th><th>Translated<br>messages</th><th>Fuzzy<br>translations</th><th>Untranslated<br> messages</th>
+ <th colspan="2">PO-Files</th><th>Translated<br>messages</th><th>Fuzzy<br>translations</th><th>Untranslated<br> messages</th>
</tr>
<?php
$arr2 = array();
@@ -29,11 +44,16 @@
array_push($arr4, $split[4]);
array_push($arr5, $split[7]);
// Sortieren der Spalte 2
arsort($arr3, SORT_ASC);
// ausgabe in tabelle basteln
foreach($arr3 as $names => $values) {
- echo "<tr><td>" . $arr2[$names] . "</td>\n";
+ $split2 = explode("_", $arr2[$names]);
+ $split3 = explode(".", $split2[1]);
+ echo "<tr>\n";
+ echo "<td>" .$new[$split3[0]]. "</td>\n";
+ echo "<td>" . $arr2[$names] . "</td>\n";
echo "<td align=\"center\" bgcolor=\"#c5e2ca\">" . $values . "</td>\n";
echo "<td align=\"center\">" . $arr4[$names] . " </td>\n";
echo "<td align=\"center\">" . $arr5[$names] . " </td></tr>\n";
More information about the grass-web
